Author Topic: Deck 108 Hassium Pro - Massdrop  (Read 1765 times)
Offline scaz
« on: Wed, 18 June 2014, 08:59:01 »
I'm new to mechanical keyboards.  I want one bad, but I don't know if this is as good deal:
https://www.massdrop.com/buy/deck-108-hassium-pro-mechanical-keyboard?mode=guest_open&utm_source=Sailthru&utm_medium=email&utm_term=Massdrop%20-%20Master&utm_campaign=Product%20Announcement%202014-06-17
k 108 Hassium Pro Mechanical Keyboard
Your top of the line video card and processing power are part of the gaming equation, but to find that function you’re after, you’re going to need a better keyboard. Giving you a full keyboard ideal for hunting down the enemy, the Deck 108 Hassium Pro Mechanical Keyboard is a high performance addition to your computing set-up.
Note: On this drop, you can choose Cherry MX Brown or Blue mechanical switches as well as White or Blue LED backlighting. You’ll also have the option to add a Hassium Palm Rest to your order.
Offline berserkfan
Re: Deck 108 Hassium Pro - Massdrop
« Reply #1 on: Thu, 19 June 2014, 01:44:16 »
Did you read this?
“Deck Keyboards is infamous for their unique legends… Instead of going with nondescript Times New Roman or any other generic typeface, the keycaps feature a font that recalls the cover of a fantasy novel without having to resort to embedding dragons.”
You really need thick skin to be an ad copywriter.
The lipstick the writer’s put on this pig really comes this close to making a new Miss Universe.
