Author Topic: Best custom case for Poker II?  (Read 10408 times)
Offline devalli
    • DevAlliant
« on: Wed, 18 June 2014, 14:44:00 »
Hi there, geekhackers!
I just placed an order for a Poker II with brown cherries and PBT caps (whites), and just wanted to know your thoughts on what custom case is best (and where to get them) for the poker.
I'm particularly interested in thick aluminum/alloy or durable resin/plastic materials for the case. I don't mind if it's heavy as it will be on my desk most of the time.
Thanks!  :)
Filco MJ2 Metallic Blue | Poker II | KUL w/ GMK Dolch
Re: Best custom case for Poker II?
« Reply #1 on: Wed, 18 June 2014, 14:46:33 »
"Best" is a subjective term, but the following are highly sought after:
Hammer alu case
FMJ alu case
Duck alu case
« Reply #2 on: Wed, 18 June 2014, 14:47:04 »
My favorite is the case from a Vortex Pure Limited Edition. I have one on both of my 60% boards. Both black aluminum. I also like TEX cases.
http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=44
Those are at MK.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #3 on: Wed, 18 June 2014, 14:49:06 »
Thanks!  :)
Personal preference but I really like the looks of the hammer case! Welcome to Geekhack btw!
Offline FrostyToast
  • Litshoard
« Reply #4 on: Wed, 18 June 2014, 15:02:11 »
The FMJ premium case is probably the sexiest case that I have seen (across everything)
Although, I think that those kinds of cases are way too flashy for me. I prefer more minimalistic looks. (aside from my extra gaudy Miami cable)
Quote from: elton5354
Offline devalli
    • DevAlliant
« Reply #5 on: Wed, 18 June 2014, 15:25:56 »
Thanks for the suggestions guys. They all look stunning!   :thumb:
I forgot to mention, I also prefer the minimalist design. I'm looking for a flat and simple design (something like a bento box). So far I like the Tex model.  :p
Just curious though, are there FMJ premiums still available for sale?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #6 on: Wed, 18 June 2014, 15:38:10 »
If you're into the low profile look then there are basically two options:
1) TEX 60% case
This comes in aluminum (MK.com) and acrylic (Massdrop). You'll have to wait until someone sells their acrylic case on the classifieds since the buy on MassDrop is over. Or perhaps they'll run the buy again?
2) Vortex Pure Case
This case original came with the Limited Edition Pure (more here), but there's a Vortex GB running that Pexon is running and there are some extras.
As for the FMJ cases, until they do another run, the only way to find them is on the classifieds.
Hoper that helps!
Offline FrostyToast
  • Litshoard
« Reply #7 on: Wed, 18 June 2014, 16:23:12 »
1) TEX 60% case
2) Vortex Pure Case
Hoper that helps!
Hehe, I have both  ;D
Offline devalli
    • DevAlliant
« Reply #8 on: Wed, 18 June 2014, 16:24:52 »
1) TEX 60% case
2) Vortex Pure Case
Hoper that helps!
Thanks for the very useful info  :thumb: The acrylic is definitely on my list.
« Last Edit: Wed, 18 June 2014, 16:27:01 by devalli »
Offline Signature
  • master of puppers
  • snoozing
« Reply #9 on: Wed, 18 June 2014, 16:44:31 »
1) TEX 60% case
2) Vortex Pure Case
Hoper that helps!
Didn't pexon have leftovers from his GB?
Anyway I think they had the same design as the tex ones though they where only 60$
Offline sdiearly
« Reply #10 on: Thu, 19 June 2014, 02:28:03 »
1) TEX 60% case
2) Vortex Pure Case
Hoper that helps!
I can show some pics for TEX acrylic CNC case.
about 2nd, this GB case isn't the same as Pure LE. the original Pure LE case is CNC, and this is molded by die casting.
« Last Edit: Thu, 19 June 2014, 02:30:47 by sdiearly »
My favorite 60%:  TEX-Beetle
                 80%:  KBtalKing Race
                100%: Cherry G80-3494, Zowie Celeritas
Offline Oobly
« Reply #11 on: Thu, 19 June 2014, 02:49:48 »
1) TEX 60% case
2) Vortex Pure Case
Hoper that helps!
I have a Pure Limited and I really love the case. The edges and finishing could well have been done better (especially considering the cost of the board), but it looks and feels awesome (and is surprisingly heavy, since the bottom is really thick near the back edge). The case pexon is selling is made by Vortex, but differs from the original Pure case in a few areas.
1. The detail and finish look better than the Pure case.
2. The back edge is thicker, the bottom is thinner and the plug hole is nicer. It probably weighs a little less.
3. It doesn't come with rubber feet attached.
The Tex case has a thicker front edge and doesn't have the built in tilt angle of the Vortex cases. In general it looks a little better made, though.
To be honest, I like them all. The Tex acrylic and aluminium, Vortex Pure Limited and newer Vortex cases are all great low profile case options. Best value right now is Pexon's GB for the black Vortex case.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline devalli
    • DevAlliant
« Reply #12 on: Thu, 19 June 2014, 02:59:09 »
1) TEX 60% case
2) Vortex Pure Case
Hoper that helps!
:thumb:
That's a nice looking acrylic you have there . Thanks for sharing. Just curious, do they flex?
Offline devalli
    • DevAlliant
« Reply #13 on: Thu, 19 June 2014, 13:45:24 »
I really like the TEX design... how I wish the side walls have uniform thickness (at least 5mm)  :-\
Offline FrostyToast
  • Litshoard
« Reply #14 on: Thu, 19 June 2014, 14:41:25 »
If you're referring to the slightly larger bottom bezel on the TEX case and how you don't like it, then the Aluminum KBT Pure case would be perfect.
The Pure case has that same minimalist, low profile design and the sides on my poker with its plate are flush which is a really nice effect.
I have one in my hands right now! (although I'm not gonna sell it)
Offline devalli
    • DevAlliant
« Reply #15 on: Thu, 19 June 2014, 23:55:29 »
I like the thick bezel on the TEX, if only all the sides have the same thickness....
Hey, if you don't mind, could you please post a picture of your Aluminum KBP Pure case, I just wanted to use it as a reference  ;D TYA!
Offline bazh
« Reply #16 on: Fri, 20 June 2014, 00:06:53 »
imsto R3 (Hammer) case is my favorite, too bad I didn't get it
HHKB Pro2 white
Newbie again
Offline sdiearly
« Reply #17 on: Fri, 20 June 2014, 01:06:13 »
I can show you these:
Left is TEX 60% case, right is Pure LE case
My bonus, with metal feets
                 80%:  KBtalKing Race
Offline devalli
    • DevAlliant
« Reply #18 on: Fri, 20 June 2014, 03:38:45 »
Wow these are nice alu cases. Thanks for sharing. Looks like the TEX has the better/smoother build quality?
Offline bahamot
    • bistropolis - dine with style
« Reply #19 on: Fri, 20 June 2014, 04:47:54 »
For sure! Tex is milled aluminium while pure is casting.
Offline sdiearly
« Reply #20 on: Fri, 20 June 2014, 08:16:13 »
Nope, Pure LE and TEX case are both milled aluminium.
But Pure LE is old one, and the factory isn't good enough.
                 80%:  KBtalKing Race
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #21 on: Fri, 20 June 2014, 08:33:54 »
I have me a hammer case that I love, and also one of my pokers is in a Acrylic case, with an acrylic and a steel plate, and I like this also.
I got boards.
Offline mauri
« Reply #22 on: Fri, 20 June 2014, 08:56:59 »
Hammer is pretty cool, but pricy. I've seen some some beautiful acrylic cases around here. There was also some guy who designed his own case here and posted pics, it was white and had a housing for the cable to fold in, it looked pretty dope but I don't think he sells em. GON makes pretty *****in' cases.
« Last Edit: Fri, 20 June 2014, 09:00:22 by mauri »
I AM BABAR KING OF THE ELEPHANTS
Offline okwchin
« Reply #23 on: Fri, 20 June 2014, 10:51:21 »
What would be the closest case to a original poker/pure case, but in aluminium, that is not low-profile.
Looking for - Thin walls, lowest height (meaning keycaps are as close to the table as possible), while having full height walls to cover up the switches.
Taobao has this case that looks neat, simple and fits the description. Might be what your after, but I don't know how to go about obtaining this.
http://item.taobao.com/item.htm?spm=a230r.1.14.169.6a5164&id=20250730167
There was thread on these too http://geekhack.org/index.php?topic=48748.0
« Last Edit: Fri, 20 June 2014, 10:54:52 by okwchin »
Offline mashby
    • Mashby
« Reply #24 on: Fri, 20 June 2014, 11:02:05 »
In that link the red case looks like the a Round 1 IMSTO case, or the MKC 60%. Without feet, that case will be completely flat. Pictures of mine can be found here.
Offline combataran
« Reply #25 on: Fri, 20 June 2014, 11:07:33 »
The one from Taobao is the Hammer case, sold out a long time ago.
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline devalli
    • DevAlliant
« Reply #26 on: Fri, 20 June 2014, 19:16:37 »
THe one from taobao looks interesting... the one next to the red case picture. (dark grey ti?)
I wonder if there is a real titanium version  :eek:
Offline devalli
    • DevAlliant
« Reply #27 on: Fri, 20 June 2014, 20:05:05 »
Anyone selling their hammer?   ;D
« Reply #28 on: Fri, 20 June 2014, 20:06:09 »
I like Duck's case
Offline combataran
« Reply #29 on: Fri, 20 June 2014, 22:17:42 »
I doubt you'll be able to find one. You could try lurking around Elton's duck viper and eagle ic thread. Apparently he's bringing in some duck mini v2s and light pads. Those have more heft if I'm correct.
Offline devalli
    • DevAlliant
« Reply #30 on: Mon, 23 June 2014, 02:46:29 »
Ok, I think I'm going with the TEX case...
I've sent a message to mk.com last week asking if they do int'l shipping (to Philippines), but didn't get a reply.
I would also be interested if someone here in geekhack wants to sell their Tex case  ;D
