Author Topic: IBM Keyboard for Cash Register - $15 shipped  (Read 2565 times)
Offline intelli78
« on: Wed, 18 June 2014, 21:24:18 »
Offline iloveucla
Re: IBM Keyboard for Cash Register - $15 shipped
« Reply #1 on: Wed, 18 June 2014, 22:11:02 »
are those sdl ps2 cable?? :eek:
Offline jevvix
« Reply #2 on: Wed, 18 June 2014, 23:14:21 »
Looks like an IBM ANPOS m7/m9. High chance of domes.
« Reply #3 on: Wed, 18 June 2014, 23:19:37 »
what's more the SDL cable that IBM uses on these is usually got 2 more pins than it needs and therefore won't work on an M.
There's a chance this cable will work with an M, as it's SDL and not for a KB with a trackpoint, but I bet it'll be compatible with the other keyboard in the line and therefore not M compatible.
We have the version with trackpoint at my old work. Domes for sure.
Offline iloveucla
« Reply #4 on: Wed, 18 June 2014, 23:50:15 »
got it, I wish it is a SDL keybaord and I'll buy it without thinking...
Offline ed_avis
« Reply #5 on: Thu, 19 June 2014, 03:42:18 »
I have a feeling IBM called this an Mx for some unusual value of x (so you have the well known M2, M13, M4 - this is another in the list) and is rubber domes.  So depending on how pedantic you want to be you can call it a Model M.
« Reply #6 on: Thu, 19 June 2014, 07:44:25 »
It is SDL. It has an SDL to PS/2 connector, it just won't fit in a model M.
ed_avis, I believe IBM used different nomenclature for their POS boards. I have one or two dome Ms that are still Ms (what with the membrane) and all, but IIRC they called these something else. I can check if you like.
Offline ed_avis
« Reply #7 on: Fri, 20 June 2014, 05:00:17 »
« Reply #8 on: Fri, 20 June 2014, 13:57:00 »
they had one of these at the KMart near where I live (picking up some shelves). RD but with what appeared to be dyesubs.
