Advanced search
it just clicks
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
Poker 2 DIP Switch Replacement
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Poker 2 DIP Switch Replacement (Read 1349 times)
Sifo
Alter
Exquisite Elder
Thread Starter
Illustrious
on:
Thu, 19 June 2014, 22:45:21 »
Any ideas what part number I could use to replace the original one as close as possible? It's 4x2 for the pin things (I believe it's SMD)
Logged
qwack
Re: Poker 2 DIP Switch Replacement
Reply #1 on:
Fri, 20 June 2014, 06:22:46 »
Any of these should do:
http://www.mouser.fr/Electromechanical/Switches/DIP-Switches-SIP-Switches/_/N-5g2s?P=1z0x3zcZ1yzcs92Z1z0z7ymZ1z0z2xxZ1z0x3zb
What you need is a 4-position DIP switch, SMT mount, 2.54 mm pitch. Check the datasheet to see if the spacing between the rows of pads is right, but they should be fairly standard. Part number SDA04H0SBD would work for instance.
Logged
Pure Pro w/MX Red - [
review
Sifo
Alter
Exquisite Elder
Thread Starter
Illustrious
Reply #2 on:
Sun, 22 June 2014, 01:54:52 »
thank you very much, sucks that I did my mouser bulk order a month or so ago and won't need anything soon
if someone is ordering from mouser hit me up
Logged
qwack
Reply #3 on:
Sun, 22 June 2014, 06:20:58 »
You should be able to find that part from any other retailer (or even ebay) since it is fairly standard, just be sure to check the specs I mentioned (any serious seller will provide datasheets for what he sells). I provided link to mouser only because it showed a lot of similar parts and datasheets
Logged
review
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
