Author Topic: Connector of IBM Model M with old silver logo(1390131)  (Read 1636 times)
Offline darkspider
« on: Fri, 20 June 2014, 09:00:44 »
Hi, I have a question about structure of 1390131's AT cable connector, which is old model of Ms.
Now, I own am using IBM Model M whose Part Number is 1391401. And this keyboard has removable PS/2 cable(grey colour).
Then, I recently bought IBM Model M P/N 1390131 with old AT cable(black one).
I want to know PS/2 cables of 1401s can be attached to 0131.
If you know, please tell me.
IBM Model F AT         Model M silver label    Model M gray label    Majestouch 2 Ninja
Brand New F62 Kishsaver / F77 Industrial Model F's made this year
Offline E TwentyNine
    • Some of My Keyboards
Re: Connector of IBM Model M with old silver logo(1390131)
« Reply #1 on: Fri, 20 June 2014, 09:13:58 »
Yes.   But the AT connector can be used with a ps/2 port via a simple passthru connector.
Offline darkspider
« Reply #2 on: Fri, 20 June 2014, 09:22:37 »
Thank you to answer my question!
You seems to be a professor of IBM's keyboards :)
Offline orihalcon
« Reply #3 on: Wed, 16 July 2014, 20:25:51 »
Yeah, any 6 Pin SDL cable (which is the removable connector that you are referring to) will work.  They only made SDL cabled model M's for PS/2 versions at least for the 101 key versions.
Offline False_Dmitry_II
« Reply #4 on: Wed, 16 July 2014, 23:40:18 »
If you don't want the AT one I'll take it. It's black which goes better with my painted black case.
