Author Topic: Program a keyboard  (Read 2218 times)
Offline Anon44
Program a keyboard
« on: Sun, 22 June 2014, 04:46:14 »
Hello,
I would like to be able to change all the fonction of the key on my keyboard. But I don't just change the key, like saying that the "i" is now a "k" or stuff like this (this is something that sharp key can help us to do), but I would like that for example the "alt" become a "ctrl" and that "maj + alt" become a "page up" for example.
Another example: on an Azerty keyboard, the "." can be accessed only with "maj + ;".
I would like to inverse the two symbole. I would like that just pressing ";" would type "." and that pressing "maj+;" would type ";".
Thanks guys!
Offline TacticalCoder
Re: Program a keyboard
« Reply #1 on: Sun, 22 June 2014, 19:43:24 »
Which OS are you on?
Offline Anon44
« Reply #2 on: Mon, 23 June 2014, 10:29:53 »
Windows 7.
I plan to install Linux (I have not the time right now) so I am also interested by the answer for Linux :)
Offline Oobly
« Reply #3 on: Tue, 24 June 2014, 09:34:40 »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Wed, 25 June 2014, 17:00:13 »
GNU/Linux: search for stuff like XKB, xmodmap, xdotools, autokey, etc. Or try Pystromo.
