Author Topic: About sip socket installation  (Read 2255 times)
Offline Ronnn
« on: Sun, 22 June 2014, 16:46:34 »
I want to use sip sockets so that I can swap leds easily, however, after reading some guides, I found most of them recommending taking the black plastic off, and I did. But soon after that I found that the leds would not sit tight in the sockets. How do I make them fit tight in the sockets so they wouldn't fall out easily?
Offline Pacifist
  • on hiatus
Re: About sip socket installation
« Reply #1 on: Sun, 22 June 2014, 16:46:59 »
put it on a LED and then solder it
« Reply #2 on: Sun, 22 June 2014, 16:55:14 »
I didn't remove the plastic. I just filed the outside of the black plastic housings down until I could force them to fit in into the properly. The LEDs fit fine.
« Last Edit: Sun, 22 June 2014, 17:04:31 by CPTBadAss »
« Reply #3 on: Sun, 22 June 2014, 17:03:28 »
I didn't do this and the LEDs still fit, but it was hard for some. I wish I had thought to clip and then install the LEDs before soldering as it would have made it a lot easier.
If you properly reinstall the top half of the switch, it can't move a whole lot.
Offline Ronnn
« Reply #4 on: Sun, 22 June 2014, 17:26:02 »
Thanks for responses! I just found that I didn't apply enough force to insert the leds...that's why it is not tight.
