Author Topic: Google Spreadsheet cell value help  (Read 2308 times)
« on: Thu, 26 June 2014, 10:33:26 »
Is there a simple way to make the value of a cell equal the file name?
I can find how to make it equal the tab, or how to do it in Excel, but I simply want the filename itself as the content of the cell.
- Oliver Willis 2026-08-01
“Conservatism consists of exactly one proposition .…There must be in-groups whom the law protects but does not bind, alongside out-groups whom the law binds but does not protect.” - Wilhoit's Law - Frank Wilhoit
Re: Google Spreadsheet cell value help
« Reply #1 on: Wed, 02 July 2014, 17:28:31 »
Over 50 views and no responses?
If anybody knows that this cannot be done, will you at least tell me that much?
« Reply #3 on: Wed, 02 July 2014, 18:06:28 »
Thanks, Ray, but the Excel method does not work in Google Spreadsheets.
I appreciate the try.
« Reply #4 on: Wed, 02 July 2014, 18:14:11 »
A little impatient huh?
This link seems to have the answer you want. Try it out and let us know if it works.
« Reply #5 on: Wed, 02 July 2014, 19:21:33 »
I have been through a lot of avenues, with no success.
I am not interested in cell values that equal sheet names, I want the filename of the spreadsheet itself.
For some reason, Google makes that very difficult.
Like so many other things, their stuff is great, in a vacuum, but not designed by people with real-world experience and needs.
