Author Topic: PCB and Matrix for G80-3000  (Read 1570 times)
Offline gotofbi
« on: Thu, 26 June 2014, 17:53:41 »
Hello.
I would like to find a pcb design(or similar) and matrix for G80-3000.
Ive been searching web for long time including geekhack and I couldnt find any matrix information for G80-3000.
Also, I am looking for some PCB design file(gerber or kicad) for standard keyboard.
So far, I only found one for GH60 but I believe there must be some for TKL and 104Keyboard as well.
I want to research more about keyboard and firmwares but I need some lot of help from community members.
Thank you very much.
Re: PCB and Matrix for G80-3000
« Reply #1 on: Fri, 27 June 2014, 03:04:33 »
Ive honestly been looking for the same thing, for the most part it seems actual detail schematics for pcb's are pretty scarce, and the folks who have any are pretty unlikely distribute for free. However that is just what I have seen, I just recently got into the Mechanical Keyboard thing, and have been creeping these forums pretty regularly for ideas and diy inspiration, so its very likely that I am just super wrong. Those are just my two cents, but if you do find anything let me know! that would be awesome!
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 27 June 2014, 06:16:27 »
The only PCBs that have been made to duplicate the 3000 have come from Korea. Most recently the Leeku. None of them had the circuit diagrams made available, nor is the firmwares for them open either.
I can not think of any open fullsize, and there are very few fullsize done for kit or aftermarket replacement part from the community. I can't think of any TKL that are completely open either, only some that have open firmware but not schematic.
« Last Edit: Fri, 27 June 2014, 06:21:03 by IvanIvanovich »
Offline gotofbi
« Reply #3 on: Sun, 29 June 2014, 16:07:46 »
I do not really need pcb design but I sure do need matrix.
The reason that I was looking for pcb file was to get the matrix of G80-3000
