Author Topic: Anyone got any info on these??  (Read 1401 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Fri, 27 June 2014, 04:23:54 »
So I stopped into my local (hour away) e-waste shop and I was talking to the guy in the back that handles the ebay side and he showed me these beautiful specimens.
This beauty has pretty short keystroke and seems to feel like rubber domes but feels very close to a MX Clear in terms of tactility and feels very even across the board.  Not mushy at all.  The legends I am guessing are lasered and old due to the fading to a slight purple/with reddish tones.
These beauties are a very linear switch with a spring on the outside of the switch mechanism.  I didn't see any soldered connections on the bottom side of the PCB but when holding up to the light you can see two large pads that almost resemble the pads on a capacitive PCB keyboard.  Any idea what these are?  If I remember correctly they said Keytronics on the bottom in a couple places printed in different methods between different boards.
Guess who said keyboard enthusiast is in the second link.
Edit:  After looking at Deskthority's wiki I am leaning toward foam and foil on the second one.  Granted they felt a bit on the scratchy side but felt surprisingly nice but had some fairly thick abs SA style caps.
« Last Edit: Fri, 27 June 2014, 05:39:07 by Melvang »
Offline ComradeSniper
  • HHKB Pro
Re: Anyone got any info on these??
« Reply #1 on: Fri, 27 June 2014, 13:28:00 »
What you're describing about the second link sounds really similar to my foam & foil board, I bet that's what they are.
« Reply #2 on: Fri, 27 June 2014, 13:34:54 »
the adds viewpoint are keytronic foam and foil. I suspected as much, and received confirmation from the seller.
I pulled off the 0, comma, and period keys off te keypad and they said KEYTRONIC on the top and SPOKANE on the bottom. Each one has a spring to make key come up after depressing. Looks like you were right. Are these of any value?
I have a vintage keytronic wang terminal keyboard that I thought was quite nice.
I was sure I read about the AID-3 on GH sometime before. Here is all I could find now when I searched though:
http://geekhack.org/index.php?topic=47318.5
« Last Edit: Fri, 27 June 2014, 13:39:31 by dorkvader »
