Author Topic: I've found an IBM model M and I have some questions...  (Read 2989 times)
Offline medvednic
« on: Fri, 27 June 2014, 08:28:42 »
Hello,
yesterday while sorting an archive of an old office I've stumbled upon an old model M which was collecting dust on top of a shelf, I live in Israel and the keyboard has Hebrew letters... I never imagined that I will see such thing here.
the most disappointing this though is that they have told me that they had many more but they were thrown to the garbage...
I've still haven't tested it but overall it seems that it didn't took damage and was laying there for about a decade if not more.
anyway, I've attached some pictures of it and I wonder if someone can you give me a little bit of info on this specific model?
what type of connector is this?
what is the best way to disassemble and clean the keyboard?
what things do I need to pay attention to while cleaning it in order not do damage it?
thanks!
IBM Model M | CM Strom QFR Stealth MX Brown
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Re: I've found an IBM model M and I have some questions...
« Reply #1 on: Fri, 27 June 2014, 08:38:23 »
Looks like a funny plug on that keyboard. I would not be surprised if it could be easily adapted to a standard AT/DIN or PS/2 plug though. Same plug, just different pin spacing.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Fri, 27 June 2014, 09:43:39 »
good find-- congrats
looks like a standard at plug to me-- just need the ps2 converter
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/11298/subcatid/0/id/179740`
check out this link...........
http://www.preater.com/modelm/
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #3 on: Fri, 27 June 2014, 10:03:19 »
Isn't that a 270 degree terminal plug?
- Bill Roberts 2026-06-17
Offline vivalarevolución
« Reply #4 on: Fri, 27 June 2014, 10:26:19 »
Looks like a 270 terminal plug.  Gonna need a Soarer's converter to get that working on a modern computer, which is not that difficult to do.
http://geekhack.org/index.php?topic=17458.0
« Reply #5 on: Fri, 27 June 2014, 13:23:23 »
That's a terminal keyboard. You can see it on the uniformly coloured function keys, two keys instead of a single keypad-+ and lack of LEDs.
You could load Soarer's converter onto a Teensy (or cheaper) and use that.
But do first clean the keyboard inside and out and see if the barrel plate is complete, would need a bolt mod or if it is cracked beyond repair. (fingers crossed)
Offline False_Dmitry_II
« Reply #6 on: Fri, 27 June 2014, 14:15:37 »
They probably tossed them because they're terminal and can't be used readily with modern computers. Soarer's converter will fix that in short order.
« Reply #7 on: Fri, 27 June 2014, 14:34:05 »
I don't think I've seen a hebrew terminal before.
Nice find! Check the trash to see if there's more that they threw out that haven't been taken away yet!
Offline medvednic
« Reply #8 on: Fri, 27 June 2014, 15:09:41 »
of course I'm going to open it and clean it soon... will order a Teensy 2.0 (btw recommendations on enclosure needed)
in my case do I have to use a Teensy can I make my own custom DIN 5 240 (female) to PS/2 male adapter?
they threw them away long time ago, but I've still tried to look for more in some forgotten corners... none were found.
one of the reasons that they tossed them is that they didn't know their historical value... such a shame.
« Last Edit: Fri, 27 June 2014, 15:14:17 by medvednic »
« Reply #9 on: Fri, 27 June 2014, 15:44:31 »
You have to use a Teensy for electrical reasons. Teensy output is USB, so your wiring will need to connect to the 4 places on the Teensy.
There are many ways to do this. There is a lot of discussion about it in Soarer's thread around #550-600.
« Reply #10 on: Fri, 27 June 2014, 16:35:47 »
you can also (apparantly) use an arduino pro micro, which are available from china, whouch they are harder to get the firmware loaded.
Offline orihalcon
« Reply #11 on: Wed, 16 July 2014, 20:12:11 »
Agreed, that is a 240 Degree 5 Pin DIN and it is a terminal type keyboard.  Soarer's converter or similar is the only thing thing that will allow you to convert.  A regular PS2 to USB adapter will not work.
