Author Topic: Military keyboards?  (Read 6060 times)
Offline Lammie
Military keyboards?
« on: Fri, 27 June 2014, 12:43:44 »
Was thinking about, what sort of keyboards military uses. Like in tactical and in the field situations. Last time I went to the Marine in Amsterdam, just saw normal Dell rubberdome kb's.
Having googled. There seems to be a paradise/heaven of Tenkeyless keyboards available..well..for military personnel at least. For example:
http://militarykeyboards.com/
http://www.cortroninc.com/
http://www.stacosystems.com/data_entry_systems/
Anyone has experience with these type of keyboards?
Topre Realforce 55g
Topre Leopold FC660C 45g
Matias Quiet Pro Mini
Cherry ML G84-4100LPAUS
Cherry MX Green QFTK
Model M Unicomp 103
Re: Military keyboards?
« Reply #1 on: Fri, 27 June 2014, 13:11:41 »
The cortron military keyboards are either hall effect or rubber dome, depending. They are also super expensive.
General Dynamics seems to have used alphameric (now part of devlin, in the UK) as their keyboard supplier. They are a fully sealed rubberdome with NKRO, something like topre. Here's some photos of mine. (the welded magnesium case and dyesubs are especially nice)
http://imgur.com/a/mg86H
I don't have much experience outside that though.
The above keyboard is from an 8 wheel military troop transport. I believe my example is from the early 2000s.
A lot of those other ones look like the KB that data911 switched to when they ditched TG3 and the BL82. I guess it's a TI?
http://www.ebay.com/itm/281002895348
« Last Edit: Fri, 27 June 2014, 13:15:10 by dorkvader »
Offline BlueBär
« Reply #2 on: Fri, 27 June 2014, 13:22:36 »
How about a Bundeswehr keyboard: http://deskthority.net/wiki/Marquardt_Military_Keyboard_7069.3111
It's mechanical and has a metal case.
Offline luisbg
« Reply #3 on: Fri, 27 June 2014, 13:31:45 »
How much does that beast weigh?
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline BlueBär
« Reply #4 on: Fri, 27 June 2014, 13:35:21 »
The Wiki entry I linked says 3,38kg.
Offline luisbg
« Reply #5 on: Fri, 27 June 2014, 13:38:13 »
Damn. Heavy but was expecting heavier. It is so monstrous it has some charm to it.
« Reply #6 on: Fri, 27 June 2014, 13:49:20 »
Like most military keyboards of old, it's actually really awesome! see the two sides fit together with a small channel with a sweet braided grounding thing between them.... it's amazing: I have always wanted one.
The alphameric is actually quite light what with the magnesium case and all. I don't have any, but I think the cortron ones aren't too heavy either.
Offline Lammie
« Reply #7 on: Fri, 27 June 2014, 14:06:07 »
That's literally a Tank of a keyboard. Found one on Amazon.com
http://www.amazon.com/dp/B004LZNW0A/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2AY2HBVI35DB9&coliid=I249QHR3JOP9I7
Reminds me of those outdoor rugged laptops. Panasonic thoughbooks. Probably more or less the same keyboards used.
Don't think the switch type is really that great on this keyboard? Price probably lies in the fact it is made rugged and outdoor friendly.
Topre Realforce 55g
Model M Unicomp 103
Offline luisbg
« Reply #8 on: Fri, 27 June 2014, 14:09:49 »
Can they be bought by civilians?
Offline BlueBär
« Reply #9 on: Fri, 27 June 2014, 14:10:44 »
The Marquardt can be found on German Ebay from time to time.
« Reply #10 on: Fri, 27 June 2014, 14:31:34 »
I've seen one on eBay after I bought mine (on eBay). There's also a few non PS/2 ones (mainly SUN protocol I think) on eBay.
I want to get another one 'cause I friend the joystick on the bottom by misapplying voltage to it :( KB works great though!
Offline Kmynis
« Reply #11 on: Fri, 27 June 2014, 16:49:30 »
I saw a Cherry ML in some documentary about a submarine. Makes sense, because it's compact, sturdy and everything is accessed without the function layer.
HHKB Type-S
Filco TKL MX Red
« Reply #12 on: Fri, 27 June 2014, 17:06:05 »
I bet this Logic Controls is tougher, what are these switches, anyway?
- D Trump 2026-10-24
« Reply #13 on: Fri, 27 June 2014, 17:20:08 »
except the numberpad
I dunno... some of those military keyboards are really tough.
Anyway, those metal domes are very commonly seen in laptop trackpad buttons and industrial keyboards.
One of the "toughest" industrial keyboards I've seen is just a huge capacitive trackpad-like thing with an overlay. It's got a controller that "interprets" keypresses and outputs PS/2.
Offline Data
« Reply #14 on: Fri, 27 June 2014, 20:43:09 »
Never saw a keyboard that fancy during my service.  :D
Offline PointyFox
« Reply #15 on: Fri, 27 June 2014, 21:06:59 »
They're called "metal dome" and they're pretty terrible to type on.
« Reply #16 on: Fri, 27 June 2014, 21:59:30 »
It would be insane to try to type on something like that!
I am trying to sell it to a restauranteur or other high-abuse venue.
Offline Lammie
« Reply #17 on: Sat, 28 June 2014, 13:02:32 »
Metal domes look very HARD to type on  :eek:
Topre Realforce 55g
Model M Unicomp 103
Offline PointyFox
« Reply #18 on: Sat, 28 June 2014, 13:07:31 »
They require an average amount of force to actuate, however it ends up being a lot more force since they bottom out very quickly and you usually have to press them pretty close to the middle to get them to work.
Offline Lu_e
« Reply #19 on: Sat, 28 June 2014, 17:22:36 »
Not military, police, but I saw this from a friend on facebook who went on a ride-along. I notice keyboards way too much now, gas stations, hardware stores and stuff lol
Just say NO to ABS keycaps
Offline User Was Banned
« Reply #20 on: Sat, 28 June 2014, 17:55:05 »
For some reason that Commodore replica set on pmk looks really military to me. I think SA in general gives me that vibe though.
« Reply #21 on: Sat, 28 June 2014, 22:08:25 »
TG3 (who made the BL82 keyboard in the photo) are one of the only OEMs capable of making a keyboard to military spec. I should have mentioned them before.
They are horrible to type on, partly because they have a silicone sheet "blood spatter guard" that makes them spill-resistant, though on older models of the BL82, they just had like a saran-warp layer that was terrible but didn't feel too bad to type on.
