Author Topic: Stupid MS Windows Does Not Stay Sleep  (Read 3491 times)
Offline Belfong
« on: Sat, 28 June 2014, 04:07:13 »
My home PC, a MS Windows 8, always wake up itself when I put it to sleep. It's as though those clacks or Brobots in the keyboard started jumping or moving to wake the PC up - no, must be some stupid settings. For the life of me, I don't know what is the settings. I've checked everything off - no wake up from LAN, no wake up from mouse movement, only keyboard.. so it must be the clacks and bots. Help!
« Last Edit: Sat, 28 June 2014, 10:51:54 by Belfong »
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: Stupid MS Windows Does Not Sleep
« Reply #1 on: Sat, 28 June 2014, 04:11:57 »
Check your switches. The Esc key is dodgy on my Pure and will fire off random keystrokes every now and again, just need to resolder it but I'm too lazy :p
Offline Belfong
« Reply #2 on: Sat, 28 June 2014, 04:30:37 »
I don't really think it's the keyboard. I have changed to another keyboard and it happened, I am suspecting it is something to do with the motherboard or probably just the OS. I suspect many here does not switch off the PC or put it to sleep so I am probably the odd one out here.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Sat, 28 June 2014, 06:06:31 »
How dare you insult Windows and call it stupid! No wonder why it's not sleeping for you.
Offline baldgye
  • Will Smith Disciple
« Reply #4 on: Sat, 28 June 2014, 06:10:11 »
Have you tried using the keyboard in another USB port?
Other than that check what you have running in the background when you try and sleep it
« Reply #5 on: Sat, 28 June 2014, 06:19:23 »
Can you unplug the keyboard completely and put the computer to sleep with the mouse only?
Offline Frenir
  • HHKB Viking
« Reply #6 on: Sat, 28 June 2014, 07:43:04 »
I've had the same problems, what I did was go into the device manager and switch off "can wake up computer" on everything except my mouse. That worked.
Apparently one of my keyboard kept waking up the pc.
(I also use windows 8 )
« Last Edit: Sat, 28 June 2014, 09:04:01 by Frenir »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Sat, 28 June 2014, 08:28:41 »
Simply sleep is broken on Windows 8.x. I have 2 PC with 8.1 and neither of them ever sleep properly. It seems there are multiple sources for the problem including it being on a network with other computers that have shares and onedrive and other modern apps syncing things very frequently. I had a workaround applied
Code: [Select]
powercfg -requestsoverride DRIVER "\FileSystem\srvnet" System Awaymodethat worked for awhile but it seemed to be defeated on the last round of Windows updates. Basically the only way I've found to get them to sleep on their own and stay asleep successfully is to disable the network connection :/
Offline Belfong
« Reply #8 on: Sat, 28 June 2014, 09:50:42 »
Thanks Ivan. I suspect it is Windows 8! This is infuriating.
To Ms widows: it is the behavior that caused me to call it stupid, so yeah, it's dumb!!
« Reply #9 on: Sat, 28 June 2014, 10:00:40 »
It's really the only thing that irritates me about Windows 8.x. Perhaps give LightsOut a try? I have it on my server2012 system and it works pretty good. I forgot they have a desktop version of it... LOL.
Offline Belfong
« Reply #10 on: Sat, 28 June 2014, 10:08:11 »
I'll try that. Now after reading your earlier post, I remember doing that powercfg command line before and turn off all the devices that was listed. And that worked. What I didn't realize was that the Windows Update defaulted it back. I just assumed that the command line was broken. Perhaps that is easier for me than installing another new program. Thanks, mate.
« Reply #11 on: Sat, 28 June 2014, 10:43:13 »
Just tested out the desktop client of lightsout... works like a charm.
« Reply #12 on: Sat, 28 June 2014, 10:43:18 »
My Linux box goes to sleep most of the times I ask it to, but not always. When it doesn't, trying again does not make it go to sleep.
