Author Topic: Finally got my Model M!  (Read 3343 times)
Offline barb
« on: Sun, 17 May 2009, 10:59:29 »
After waiting some time (the guy I ordered them from was pretty slow), my new keyboards arrived!
I got three with part number 1391411, one built in 1990 and the other 1992. The third was built in 1996, and does not have a detachable cord. Very strange! Or maybe not.
I really like these keyboards! They both sound and feel great. :)
Took a while to get used to, but I feel like my typing speed and accuracy has increased a bit. A quick test showed 84 wpm, a slight improvement over previous results.
I tried painting one of them black, with pretty good results. I used vinyl paint, and hopefully it won't peel off or anything. Time will tell.
Some pictures:
This is the label of the one I painted. I managed to peel it off and reattach it after painting!
Action shot!
best plastic material used, durable for continual baby punch
Offline barb
« Reply #1 on: Sun, 17 May 2009, 11:49:45 »
Thanks! I am very happy with the result. There are some tiny white spots that I will probably correct later. I was a bit too eager to assemble it and accidentally nicked it a little.
I used something called vinyl paint, apparently used for painting imitation leather and things made of vinyl etc. It supposedly "sinks into" the plastic, I guess just like rit dye. I heard it works great on plastic too so I tried this. :)
And yeah I got them really cheap! One of them is missing four keycaps though, which is not that nice. The seller promised he would look for replacements in his giant pile of old computer stuff. I hope he finds them!
Edit: Oh, and as you can see I painted over the part with the LEDs. Half way through I noticed I had forgotten to tape over the logo and the LED part. Too bad, but it still looks pretty cool. :)
« Last Edit: Sun, 17 May 2009, 11:54:16 by barb »
Offline watduzhkstand4
« Reply #2 on: Sun, 17 May 2009, 12:07:56 »
nice pick up and clean paint job!
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline o2dazone
« Reply #3 on: Sun, 17 May 2009, 12:57:29 »
I've used vinyl paint on the interiors of cars (ABS plastic). Holds up amazingly well, but then again, I'm not putting my fingers on it like I am a keyboard. Holds up to 130f heat though lol - keep us posted if it flakes or fades
Offline wellington1869
« Reply #4 on: Sun, 17 May 2009, 16:16:34 »
nice paint job
back when we were talking about dyeing the keyboards (in that dye thread) I think someone mentioned that vinyl paint eventually peels. I guess here's another experiment. keep us posted on that!
using: ms 7000/Das 3
Offline ch_123
« Reply #5 on: Sun, 17 May 2009, 17:09:36 »
Which country were the 1391411s made for?
Offline skriefal
« Reply #6 on: Sun, 17 May 2009, 17:24:11 »
Look at the photo of the rear label, above... :smile:
(Oops... I thought you asked what country they were made in...)
« Last Edit: Sun, 17 May 2009, 20:51:34 by skriefal »
Offline xyzzy
« Reply #7 on: Sun, 17 May 2009, 17:52:39 »
Quote from: ch_123;91375
According to Wikipedia, 1391411 is Swedish layout
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline barb
« Reply #8 on: Mon, 18 May 2009, 02:28:48 »
Yes they are Swedish.
I've noticed the right shift key gets stuck sometimes. I hope its just temporary because of the paint.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #9 on: Mon, 18 May 2009, 08:00:55 »
Quote from: barb;91409
The one on my main 1391403 also likes to do that (or at least can't be moved easily) if you engage it at the very right corner. If it doesn't want to move up again, however, then something must be sticky. In that case I'd pop off the key and remove any paint on the mechanically relevant parts.
