Author Topic: G81-1800LAAUS $35  (Read 3437 times)
G81-1800LAAUS $35
« on: Sun, 29 June 2014, 00:03:31 »
« Last Edit: Sun, 29 June 2014, 00:19:10 by nubbinator »
Offline bexleycorona
Re: G81-1800LAAUS $35
« Reply #1 on: Sun, 29 June 2014, 02:10:25 »
That's a pretty cool looking actually.
What type of switches does it have?
GE Marquette | Rosewill RK-9000 | Rosewill Apollo 9100 | Realforce 87U "EK Edition" 45g Uniform | Unicomp Ultra Classic Black Buckling Spring | Realforce 87U SE07T0 Variable | Dolch PAC65
Offline Doesntknowwhattosay
« Reply #2 on: Sun, 29 June 2014, 05:09:38 »
Cherry MY Switches. I believe they are linear and feel a little bit mushy.
Offline Battou62
« Reply #3 on: Sun, 29 June 2014, 14:31:30 »
Cherry MY switches feel like crap. I recently picked up a two tone set off of a G81-3000. The key caps feel surprisingly nice, and the legends look really good for laser. Be aware that you wont be able to use the majority of the mods though. They have some weird stabs that are built into the key caps. This is what is usable on a Filco.
http://i.imgur.com/saKJRAZ.jpg
Offline Pacifist
  • on hiatus
« Reply #4 on: Sun, 29 June 2014, 14:43:51 »
WRONG
You can use everything on this board, because its 1.5x. But if you try to use it on a filco, yes it'll look somewhat like that, but if you do it on a MX board with 1.5x and off center caps, all will work
« Last Edit: Sun, 29 June 2014, 14:45:23 by Pacifist »
Offline Battou62
« Reply #5 on: Sun, 29 June 2014, 16:31:44 »
This is what I was referring to.
http://img02.taobaocdn.com/imgextra/i2/783706884/T2BnNcXcROXXXXXXXX_!!783706884.jpg
You can see the floating mods there. If the boards OP mentioned aren't like this then my apologies. I assumed they would be, but my cheery-foo is relatively weak :)
Offline Pacifist
  • on hiatus
« Reply #6 on: Sun, 29 June 2014, 18:07:49 »
its a winkeyless, 1.5x MY, which has centered stems like MX. Only 1.25 is uncompatible
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Sun, 29 June 2014, 19:32:44 »
It's recent production so even though it has 1.5 modifier the keys that are stabilized still may be like that. This ONLY effects PBT (white/beige lasered set) so consider yourselves warned.
If you want Cherry PBT new sets, you can get Cherry KC104 sets that are for MX for even less off TaoBao. Those only come in ANSI 104 though.
« Last Edit: Sun, 29 June 2014, 19:37:14 by IvanIvanovich »
Offline Pacifist
  • on hiatus
« Reply #8 on: Sun, 29 June 2014, 19:37:41 »
could you shave off the excess?
« Reply #9 on: Sun, 29 June 2014, 20:03:18 »
Yeah I suppose, but they still won't have stem for Cherry type stabs so they would be all wobbly. They sort of work with costar type if you adjust the wire part.
Offline Battou62
« Reply #10 on: Sun, 29 June 2014, 21:08:13 »
I tried shaving the excess plastic off, and it wasn't too hard to do.  But yeah, you don't have any stems for stabs, and those mods feel real bad without stabs.
Offline Battou62
« Reply #11 on: Sun, 29 June 2014, 21:18:36 »
But they don't have two tone. I believe B7ad has a set of these for sale.
