Author Topic: Cherry keyboard manager: remap 'z' into 'y'  (Read 4456 times)
Offline Lammie
« on: Sun, 29 June 2014, 08:16:20 »
Hi,
Heard about the Cherry keyboard manager software, to remap certain keys. I want to know if it is possible to remap the 'z' key into a 'y' key (qwertz into qwerty)?
Topre Realforce 55g
Topre Leopold FC660C 45g
Matias Quiet Pro Mini
Cherry ML G84-4100LPAUS
Cherry MX Green QFTK
Model M Unicomp 103
Offline BlueBär
Re: Cherry keyboard manager: remap 'z' into 'y'
« Reply #1 on: Sun, 29 June 2014, 09:01:13 »
Cherry.de seems to not load for me but I'll try to help you without knowing exactly what that software does.
Only very few Cherry keyboards can be programmed on a hardware level (meaning that they keep their programmed functions even when you attach it to a different computer).
If your keyboard can not be programmed on a hardware level, the most common approach would be using a program like AutoHotKey.
Offline Lammie
« Reply #2 on: Sun, 29 June 2014, 10:05:29 »
Thanks for your help. Looking forward hearing from you.
Topre Realforce 55g
Model M Unicomp 103
« Reply #3 on: Sun, 29 June 2014, 10:07:06 »
Most of the cherry keyboards you cannot program the alpha keys. The only one I can think of offhand is the G80-1950 and it's terrible.
You can usually just switch to german layout or whatever using your computer.
Another option is to use software like keyremap4macbook or autohotkey (windows).
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sun, 29 June 2014, 10:35:44 »
Best way would be to use other language keymap, or customize keymap if you did want to move Z/Y on DE for example. The legends on the keycaps do not control what the keyboard does, the language keyboard map file in the OS does that where it assigns a charachter to the scancode the keyboard sends. So I can plug in FR azerty board and type US qwerty on it as the OS has no idea what is on the keyboard.
