Author Topic: quick mousepad recommendation  (Read 4706 times)
Offline Pacifist
  • on hiatus
« on: Mon, 30 June 2014, 23:02:41 »
My qck is almost 3 years old, and pretty dirty. I want something just a tad smoother. Any suggestions?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: quick mousepad recommendation
« Reply #1 on: Mon, 30 June 2014, 23:19:50 »
xtrac xxl is legit. Super smooth.
Logitech new G series has gotta some good reviews...
Offline munch
« Reply #2 on: Tue, 01 July 2014, 02:31:32 »
Artisan Hayate if cloth is what you're after, extremely smooth and great precision.
Razer Manticor feels super smooth too, but it's aluminium and on the pricier side :p
not sure if size is a big deal but there's also something like the modmymachine slamepad, another aluminium pad that is extremely smooth and seems very high quality (I've had mine for a while now, no wear whatsoever)
and the Artisan Raiden, which I absolutely love - my favourite cloth pad. very smooth but has issues with some optical mice (Kana v2 wouldn't work at all, for example. but other a3090 mice work, like my zowie mice)
and the all-popular Icemat, not available anymore new unfortunately it seems, is my favourite super smooth pad.
but I would assume you want a soft pad, and my suggestions are the Artisan then. they're worthy the praise they receive. do note that you SHOULD use a microfiber or something maybe once every month just to make sure it doesn't get too dusty :p it is very finely woven and dust might stick a bit. not a big issue but just... general maintenance for pads.
the hard pads require almost daily cleaning though, so uhh... no idea if you'd care for them. :D
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Tue, 01 July 2014, 09:01:00 »
I would recommend investing in a premium Internet Explorer mousepad:
http://geekhack.org/index.php?topic=49858.0
Offline Zekromtor
    • My Setup
« Reply #4 on: Tue, 01 July 2014, 10:03:02 »
Maybe we can do a group buy and get the price down to $37.98 or something.
« Reply #5 on: Wed, 02 July 2014, 11:15:40 »
I'll donate 0.02% of the proceeds from these Internet Explorer mousepads to governments who take money from poor people in Africa. That way I'll be a nonprofit charity who cares about the world.
Offline Kiwi_321
« Reply #6 on: Sun, 06 July 2014, 20:21:17 »
I'm always happy to recommend the Goliathus. It's a cheap $20 for a decent quality item. One of those things in gaming that isn't ridiculously overpriced (although...the cost of goods on these is probably significantly less than $20!)
Offline Prelim
« Reply #7 on: Thu, 10 July 2014, 14:35:19 »
get the zowie g-tf speed
I have tried almost every clothpads in the market and this is the best one I've tried ever!!
review: www.infohw.com/2012/02/review-zowie-g-tf-speed/
« Last Edit: Thu, 10 July 2014, 16:13:17 by Prelim »
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline AlleyViper
« Reply #8 on: Thu, 10 July 2014, 15:38:16 »
My Goliathus Speed has 3 years of use and the cloth is good as new (didn't seem to lose any coating properties). Also, it's the old version without stitching on the borders, but it never peeled where the wrist scrapes.
Offline JackCY
« Reply #9 on: Tue, 22 July 2014, 12:00:01 »
Your budget and what is available in your area?
Here Razer is overpriced, I could get 2 and half QCKs for one Razer Goliathus pad.
QCK is QCK, it will not stay as new for long years. But probably nothing will, dirt and dust and dead skin and all the crap gets pressed into the cloth mats.
I got Roccat Taito but if Goliathus was cheaper would probably get it.
Other than that it's difficult to get other mouse pads here, not common in shops, hard to find info about as well.
I would be wary of any modified edges and stitching and such, it can seriously irritate your hand if you will be gliding over it. I know I glide over the edge so it would be an issue for me if it was raised or not very smooth as the pad.
QFR red
