Author Topic: IBM Model M - new user question  (Read 2462 times)
Offline Rainman
« on: Tue, 01 July 2014, 17:45:50 »
Hi guys, I just recently got my hands on the IBM model M. I've bought this keyboard a couple of days ago and I have to say, after a thorough clean, it looks fairly new. Anyways, now I've got a question regarding the keys, namely some keys require a bit more push than the others and some even have a bit of a "metaly" sound. It's not a big difference but it can be felt if paying attention to it. Now I'd like to ask all the owners of IBM Model M if that's normal with these keyboards? Could it be the buckling springs need a change or what could be the cause of a slight uneven pressure force and the slight higher-pitched "metaly" sound for the keys? I appreciate the input guys...
Rocking Poker 2 with vintage MX Blacks
Offline Pacifist
  • on hiatus
Re: IBM Model M - new user question
« Reply #1 on: Tue, 01 July 2014, 18:02:30 »
are they seated correctly?
Offline brainT
« Reply #2 on: Tue, 01 July 2014, 18:06:14 »
This.
And you could also pop the case open and see if you're missing any rivets.
Offline Rainman
« Reply #3 on: Tue, 01 July 2014, 18:09:44 »
Thanks guys for your quick answer.
Yes, every keystroke is properly recognized... maybe there is a special technique for placing the keycaps on top of the springs?
Tomorrow I'll open the case and inspect for missing rivets... anything specific detail I should look for?
« Reply #4 on: Tue, 01 July 2014, 19:00:41 »
Also it might need a bolt mod.  If some of the plastic rivets have come off, it could result in an inconsistent feel across the board.  One of my Model M is like that.
Offline brainT
« Reply #5 on: Tue, 01 July 2014, 19:11:17 »
Great video on restoring a Model M!
Offline Hellmark
« Reply #6 on: Tue, 01 July 2014, 19:23:58 »
You can have a key improperly seated and still have the key presses register.
My rule of thumb, is if the keyboard has been shipped, make sure to pop and reseat each key. The ones I've got, I've had had at least one or two keys knocked a bit out, so it would just feel weird. It is fairly quick and easy.
After that, make sure to check the rivets. If you have a bunch that have broken free (which can be common, they're just plastic), then you'll want to do a bolt mod. If it is just a few here or there, then it isn't as big of a deal. Only time I'd consider doing a bolt mod if a few have broke loose, is if they're all right next to each other (uncommon, and usually indicative of some sort of accident).
Offline Rainman
« Reply #7 on: Wed, 02 July 2014, 15:57:18 »
Thank you guys for this thoroughfull information. I popped the case open and I saw that all the plastic thignys are intact, the keys are properly seated. I come to think that this is how the model M should actually feel and sound. My model M is from 1993 (with the blue IBM logo). I'll try to upload typing video and post it here so you can here the sound of the keys by yourself. Nevertheless I really enjoy the Model M and I have to say it does need a bit of typing practice before one gets used to the buckling springs (I came from Cherry MX browns). All in all, after you get the hang of it, one really starts to dig that loud clicks. ;)
« Reply #8 on: Wed, 02 July 2014, 16:41:34 »
Dorkvader did this experiment last year where he brought like 4 Model Ms around and they all felt different. He didn't bolt mod them or anything. Just because the rivets are intact doesn't mean they're retaining properly and giving you the "Model M feel". I personally judge all Ms off of my bolt modded SSK.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #9 on: Wed, 02 July 2014, 16:59:21 »
exactly.......... my other m feels or even sounds nothing in comparison like my bolt modded m.
i did take some thin styrofoam, place behind the plate and even duct taped the inside of the case to help with some of the pinging. it probably at least cut it in half or better, but is still not as tight, responsive, etc. as my bolt mod. all the springs for being as old as they are-- are still very springy
still gotta dental mod, but i have gotten used to it and it doesn't bother me
they are probably my favorite KB.............love it late at night and all the racket the thing makes :eek:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Rainman
« Reply #10 on: Wed, 02 July 2014, 17:08:39 »
OK, now things got complicated... :)
Does one have to take the whole keyboard apart to apply that bold mod or is it just enough to remove the plastic rivets with a sharp razor and then drill through?
« Reply #11 on: Wed, 02 July 2014, 17:31:05 »
Both ways are possible. The second might be more properly called the "screw mod" but you are using machine screws in any case.
Peeling layers apart dramatically increases the time and effort involved in this procedure, but allows you to clean and adjust everything.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
