Author Topic: HHKB-Compatible USB Flash-drives?  (Read 1622 times)
Offline Frenir
  • HHKB Viking
« on: Wed, 02 July 2014, 10:55:01 »
I've got this idea of having a usb flash-drive with a portable version of autohotkey with all my scripts in my HHKB at all times for extra portability.
But since I know that the HHKB has a very limited usb-hub I would like to ask if you know some drives that are compatible, I've had no luck so far.
Offline MJ45
  • HHKB Pro
Re: HHKB-Compatible USB Flash-drives?
« Reply #1 on: Wed, 02 July 2014, 11:16:44 »
The only USB flash drive that works with my HHKB is a Corsair flash Voyager.
Offline Frenir
  • HHKB Viking
« Reply #2 on: Wed, 02 July 2014, 12:58:24 »
Hmm okay, I would wish there was something a little more subtle that I could use.
Do you think this would work ?
