Author Topic: Superlube to lube switches  (Read 10496 times)
Offline yuktsi
  • Colour my life with the chaos of trouble
« on: Wed, 02 July 2014, 11:50:06 »
Is it okay to Superlube grease to lube my switches?
According to this table
http://www.super-lube.com/files/pdfs/Super_Lube_Compatibility_Chart.pdf
It seems pretty stable to apply it on POM, ABS and PBT.
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Re: Superlube to lube switches
« Reply #1 on: Wed, 02 July 2014, 11:54:43 »
No, please don't. Krytox is available now. No need for other lubes.
« Reply #2 on: Wed, 02 July 2014, 12:12:25 »
The "why" to your reply is because superlube is too thick right jdcarpe?
« Reply #3 on: Wed, 02 July 2014, 12:15:33 »
It's too thick for use on stem sliders, it degrades over time, it requires reapplication after several months of use, it leaves a nasty mess inside the switch, it would actually make your keyboard less desirable at resale, etc, etc...
« Reply #4 on: Wed, 02 July 2014, 12:16:29 »
That's right...I forgot it degraded and shifted about.
Offline egroeg555
« Reply #5 on: Wed, 02 July 2014, 14:00:37 »
Any particular reccomentions of Krytox lube?  I recently got a Quickfire Rapid with red switches and I've been reading to figure out what would be a good choice for lube/grease.
Should I order some 205 grease and use it on everything?  Stabalizers, sliders, stem, spring...   Or is it better to have a mix (206 and 1506) like is sold on mechanicalkeyboards.com.  And then there is there would be the choice of whether to get their thin, thick, or extra thick mixture.
Or, perhaps it is better to get both and use the 205 on the stabalizers and spring and the mix on the sliders and stem, or something like that?
« Last Edit: Wed, 02 July 2014, 14:05:04 by egroeg555 »
« Reply #6 on: Wed, 02 July 2014, 14:07:56 »
I use a mix of 205 grease and 103 oil (or 206 grease and 1506 oil). I just mix it until I like the consistency. But yes, I recommend the lube kits sold at geekhackers.org (OOS), techkeys.us, ctrlalt.io, and mechanicalkeyboards.com. I don't remember what the thicknesses are recommended for.
For springs I use Victorinox Multi-tool Oil. And 205 or SuperLube for stabilizers.
« Reply #7 on: Wed, 02 July 2014, 14:15:06 »
I still use ro59 for personal projects :( but for customers I do Krytox
Offline Sniping
« Reply #8 on: Wed, 02 July 2014, 14:41:08 »
You should get the thin mix from mechanicalkeyboards.com. The thick mixes are for tactile switches.
Offline egroeg555
« Reply #9 on: Wed, 02 July 2014, 15:00:42 »
Okay, soulds like one could at least reasonably use the super lube on the stabalizers.
Any particular reason not to use the grease/oil mix on the springs?
« Reply #10 on: Wed, 02 July 2014, 15:04:07 »
It's expensive. :D
Victorinox Multi-Tool Oil is $5-7 for a 5mL bottle.
Offline egroeg555
« Reply #11 on: Wed, 02 July 2014, 17:03:43 »
It's expensive. :D
What about Militec-1?  Does anyone use that on the springs?
