Author Topic: Model M making springy noise?  (Read 2624 times)
Offline xSpartanCx
« on: Wed, 02 July 2014, 14:59:44 »
I have a used model M and when I tap a key quickly some of them make a springing noise when they come back up. Should I get new springs? If so, where? Is this normal?
EDIT: By springy noise I mean a high piched ringing "ping"
« Last Edit: Wed, 02 July 2014, 22:36:53 by xSpartanCx »
Offline smknjoe
Re: Model M making springy noise?
« Reply #1 on: Wed, 02 July 2014, 15:05:32 »
I'm not sure if this is a serious question or a joke. The mechanism used is a spring. So, it's going to sound like...a spring.
SSKs for everyone!
Offline xSpartanCx
« Reply #2 on: Wed, 02 July 2014, 15:16:10 »
Ha, I meant that it makes a "ping" noise and want to know if there's any way I can change that.
« Reply #3 on: Wed, 02 July 2014, 15:31:50 »
Dental floss mod is probably your best bet.
http://geekhack.org/index.php?topic=9761.msg1238134#msg1238134
- D Trump 2026-10-24
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Wed, 02 July 2014, 15:33:55 »
.............and not a pingy kind of noise?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline xSpartanCx
« Reply #5 on: Thu, 03 July 2014, 19:23:42 »
Looks good, I'll try that out next time I go to the pharmacy and get that "fluffy" floss
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #6 on: Fri, 04 July 2014, 03:25:47 »
This is the SINGLE most useful idea to modify a Model-M keyboard without ripping it all apart.  Thank you to anyone for first mentioning this  :thumb: .
Offline 1391406
« Reply #7 on: Fri, 04 July 2014, 20:20:22 »
The floss mod also dampens the click a bit, which I'm not crazy about. If there's one thing I like about Unicomp it's that they managed to alleviate the metallic ping without affecting the click.
« Reply #8 on: Fri, 04 July 2014, 21:57:27 »
For me, the floss mod is perfect and essential on the Model F, I have done all of mine without hesitation.
It is far less satisfying on the M, and I really prefer Ms without.
But that is probably because the F feels so much more "alive" than the M, and I am far more concerned with feel than sound.
