Author Topic: What software?  (Read 1167 times)
Offline Blackehart
What software?
« on: Wed, 02 July 2014, 18:09:55 »
To check mapping on a Kmac 1.2?
I've shot several PMs to the seller but I get no reply.
I want to see what combo the lighting is set to.
EDIT: BY THE WAY! I have an LZ-skin and i use Trikster ( i think that is what it's called) and i can toggle stuff on and off just fine. It won't load anything for the KMAC.
I also dug up some software from an old thread (name escapes me), but it seems  unable to read the layout.
Thanks in advance,
-Blacke
« Last Edit: Wed, 02 July 2014, 18:48:29 by Blackehart »
Re: What software?
« Reply #1 on: Wed, 02 July 2014, 20:07:15 »
here is a link to a GH topic that lists the KMAC software and how to use it
http://geekhack.org/index.php?topic=49647.028
If you just want to reprogram, you can use Hasu's TMK_firmware of Mettaliqaz's easy remap software, but I believe only the original KMAC program can read the current layout.
Offline Blackehart
Re: What software?
« Reply #2 on: Wed, 02 July 2014, 23:30:39 »
Thanks! That worked like a charm!
 ;D
