Author Topic: Help finding dar/black translucent wasd keycap set  (Read 2181 times)
Offline badman5
« on: Thu, 03 July 2014, 22:59:28 »
Does anybody know where i can get a set of those keycaps but only the WASD and arrow keys? i dont need a full set.
http://www.maxkeyboard.com/max-universal-black-translucent-mechanical-keyboard-keycap-set-top-print.html
Offline deltuhhh
Re: Help finding dar/black translucent wasd keycap set
« Reply #1 on: Fri, 04 July 2014, 13:16:19 »
I know they sell the WASD with some other keys on mechanicalkeyboards.com. I don't know about the spacebar though.
« Reply #2 on: Fri, 04 July 2014, 13:54:03 »
what the heck even is your avatar
that's so strange
and yeah they have the WASD at MK but the spacebar you can only get with the full set
Offline badman5
« Reply #3 on: Fri, 04 July 2014, 14:51:02 »
thanks, but not  exactly what im looking for. Looks like the only way to get translucent top print is to buy an entire set.
« Reply #4 on: Fri, 04 July 2014, 14:52:40 »
that's not that horribly expensive, right? only $45 or something
Offline Vaii
  • wat
« Reply #5 on: Wed, 09 July 2014, 13:33:23 »
Yeah theres quite a few keysets that are a lot more expensive than this one.
Can also maybe try and sell parts of this set to get back some money!
Obviously the keys you don't use
wtb dark plushberry (mx) bbv2 / starcluster (mx) bbv2
