Author Topic: is there a tool for keycap row identification ?  (Read 5564 times)
Offline querolous
« on: Fri, 04 July 2014, 17:34:47 »
I'm new to this,
is there a quick, reliable tool for identifying an MX keycaps' row
are there easy to read diagrams showing the differences?
my eyesight is not good
Offline Pacifist
  • on hiatus
Re: is there a tool for keycap row identification ?
« Reply #1 on: Fri, 04 July 2014, 17:37:51 »
not really, just compare it to something you know the row of
« Reply #2 on: Fri, 04 July 2014, 17:43:41 »
if you're confused about a set you can just ask in simple questions, it's pretty easy to tell by eye after a while and we're always happy to help
Offline Aidenknives
« Reply #3 on: Fri, 04 July 2014, 23:32:10 »
Try to have another put together board right next to it.
« Reply #4 on: Sat, 05 July 2014, 00:46:37 »
I'm new to this,
Registered in 2013 and this is your first post?  Taking lurking to a new level :D
Welcome to Geekhack!
Are you referring to printed or blank keycaps?
If printed, you can Google for keyboard and compare layout to most pictures.
If blank, many blank sets have a number engraved underneath to identify what row they belong to.
Offline querolous
« Reply #5 on: Sat, 05 July 2014, 02:36:40 »
my project in 2013 was the same as it is now, just a very slow thinker with long spans between activity. :)
initial aim is to re keycap my old maltron right-handed keyboard
black keycaps with orange lettering is my current aim if I can source them to fit.
(the default dark grey lettering on a light grey background is not easy for me to read)
after reading the first posts, I've ordered a blank R4, R3, R2 and R1 keycap so I know (which if any of these are currently installed,) what/where they are and how any variation feels when in use.
« Last Edit: Sat, 05 July 2014, 02:39:11 by querolous »
« Reply #6 on: Sat, 05 July 2014, 04:06:57 »
The only orange on black I've seen is BunnyLake's The GeekHack 60% Nostalgia Keyset GB (now finished).
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #7 on: Sat, 05 July 2014, 05:03:47 »
Don't forget the charred orange GMK set (skidata replica).
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #8 on: Sat, 05 July 2014, 07:35:08 »
A Ghost From The Past
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #9 on: Sat, 05 July 2014, 07:57:07 »
These people (at deskthority.net) have done a lot of work on this subject.
You should take a look  ;)
Offline Kayla
  • :3
« Reply #10 on: Sat, 05 July 2014, 09:19:14 »
Compare bottom row to your 1.25 mod keys.
Compare shift row using shift keys.
Compare caps lock row with caps lock key.
Compare tab row with tab key.
Compare ~ row with backspace key.
All F row are huge.
Offline querolous
« Reply #11 on: Tue, 15 July 2014, 14:16:58 »
The cylindrical keycaps I ordered arrived in today :)
All my default Maltron keys are of the spherical type, most visually similar to cross-sections of the DSA family of keycaps, though at a different physical size.
sampling two single maltron keycaps gives measurements of:
81.5mm (0.32"), 8.06mm (0.317") tall
18.09mm (0.712"), 18.04mm (0.710") long square base sides
the shallowest dip for each key is within the range of 0.8mm to 0.9mm (0.31" to 0.35") but it isn't easy for me to measure this consistently
The first of these keycaps is from a maltron keyboard more than a decade old, the second keycap is from a set bought direct from maltron around a year ago.
thankyou for all the information, time for me to try out some keys and think about what happens next. :)
