Author Topic: [IC] - Matias 60% ALPS keyboard with Cherry-compatible PCB  (Read 339627 times)
Offline Norwegian
Re: [IC] - Matias 60% ALPS keyboard with Cherry-compatible PCB
« Reply #100 on: Sat, 12 July 2014, 06:15:23 »
I am definitely interested.
- PC
- ISO (Nordic. Yes I do like my ÆØÅ's...)
- Option A.
- Clicky ALPS
- Fully Assembled Keyboard
What color-scheme will the case/keys come in? Perhaps you've already answered, so sorry for missing it.
Ducky Shine 2 Green LED MX Brown | Filco Majestouch2 91 TKL MX Red | Model F 5150 XT | Model M 52G9658 | Leopold FC660M MX Green | HHKB Pro2 PD-KB400W
Offline RED-404
« Reply #101 on: Wed, 16 July 2014, 13:29:46 »
I just wanted to check if you planned on a nice minimal keyboard case like what's in the mockup or where you going with one of your standard old iMac stile cases? Frankly, the main reasons I have never bought a Matias is simply the look of the case.
If you're doing a minimal case like a Poker, Tex or Hammer then I will buy it, I really like the layout and have no problem with the none standard size keys.
Offline hjkl_over_wasd
« Reply #102 on: Sat, 19 July 2014, 11:51:53 »
Hi Matias. How's the project coming along?
I have one more question/request:
I have just gotten an HHKB and I'm faced with the choice of either changing my muscle memory to hit the key right above (ANSI) enter to do a backspace, or keep using what is common ANSI and have backspace at the top right.
In other words, I might have to remap my HHKB and stay with the common layout for the backspace key.
I do understand the rationale for having backspace right above the enter key on an ANSI layout, but this will completely mess up my muscle memory. The thing is that I already am used to having ctrl and esc as caps lock in a dual role setup, but in my opinion, this it completely worth having even though it completely deviates from the standard. Since I already am using an unconventional keyboard layout, I am doomed to never feel comfortable on a default keyboard layout anyways and will most likely have to bring a 60% wherever I have to work on a computer for more than half an hour.
Then it only boils down to one factor:
(TL;DR)
Will/can there be a DIP switch setting to toggle HHKB backspace positioning for the Matias 60% keyboard?
This would flip the positions of the '\|'-key and backspace.
« Reply #103 on: Sat, 19 July 2014, 12:16:12 »
One more idea:
What about mapping shift+backspace to Del?
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
« Reply #104 on: Wed, 23 July 2014, 15:43:55 »
Note, PBT keycaps from the 80s / early 90s (including Apple’s) don’t really experience much yellowing, or benefit from retrobrite [the cases and ABS spacebars on the other hand...]. What they do get is dirty, so I’d recommend soaking them in denture cleaner or detergent, and maybe scrubbing the especially dirty ones a bit with a sponge.
Yes, that's true.  I've changed the link to something more appropriate.
Stock colour will be black, but we'll be selling white keycaps soon, and eventually other colours.
Yes, it will be minimalist, as shown in the drawings.  I'm leaving for China on Sunday and will be working on it while I'm there.
(TL;DR)
Okay, will consider adding this.  Seems a little odd, though.
Better you remap that in the OS.  I'm sure some software will conflict if we do it in the keyboard.
Offline geniekid
« Reply #105 on: Wed, 23 July 2014, 15:52:41 »
(TL;DR)
I found the HHKB layout allowed me to hit backspace without moving my right hand off the home row.  I can do this on a normal layout but I have to turn my arm.
Offline Matias
    • http://matias.ca
« Reply #106 on: Wed, 23 July 2014, 16:15:52 »
(TL;DR)
Are all HHKB set up this way?
Offline geniekid
« Reply #107 on: Wed, 23 July 2014, 16:33:30 »
(TL;DR)
I don't know about the JP version, but I believe all Western versions are setup this way.  Actually, by default, the key in question is set to Del and Backspace is Fn+Del.  You can toggle a dip switch to make it Backspace (with Fn+Backspace=Del).
See this picture from EK:
« Reply #108 on: Wed, 23 July 2014, 23:20:00 »
After I've been using my HHKB for a week or so, I've come to realize how important the design of the keyboard case really is. The thing that really ruins it for me when it comes to the HHKB is its case. I find that the keys are angled pretty steep by default and the board comes with legs that can tilt the angle even more.
Will the case for the Matias 60% have a flat angle and relatively low profile?
The TEX aluminum case is really nice. Completely flat angle and only 13mm tall.
« Reply #109 on: Thu, 24 July 2014, 00:01:28 »
You mentioned something about a fiberglass plate. Will this be the default plate material, or will it be steel? If you're going for steel plates as the default, can we choose to get a spare fiberglass plate if we're part of the group buy?
Offline Matias
    • http://matias.ca
« Reply #110 on: Thu, 24 July 2014, 09:59:01 »
Okay, thanks.
Seems like they designed it for a specific variety of Unix user.
Our plan is to offer steel plates, unless the MOQ is not reached for a particular layout -- in which case we would offer a fiberglass plate for that layout.
Of course, if you have a specific request for fiberglass, that's no problem.  MOQ for fiberglass is 1pc.
Yes, it will be as low profile as we can make it, with a very slight slope.  See attached.
[ Note that I edited the image originally posted, to better reflect what it'll actually look like from the side. You'll see the green part. The grey foot mounts will be positioned further inward, and mostly obscured from view. ]
Was planning to include feet, unless there are strong objections.
72289-0
« Last Edit: Thu, 24 July 2014, 10:52:38 by Matias »
Offline FuriousGeorge
« Reply #111 on: Thu, 24 July 2014, 11:49:29 »
Are the arrow keys higher than the rest of the bottom row? I had seen the earlier pictures and I think I assumed that area was raised because it was using a different switch that was shorter and needed the extra height. I realize now that with the smaller size of the switches it's probably just a normal switch and it will actually end up being taller. I'd suspect it's to make the arrow keys easier to locate by touch, but with the blank spaces to the left and right of up arrow I would think it would already be easy to pick it up. It may be too late to change, but personally I'd prefer to have the bottom row a consistent height.
« Reply #112 on: Thu, 24 July 2014, 12:32:50 »
Great! My key mashing fingers don't like hard surfaces like steel.
My wrists really don't like any angles, so if it's possible to somehow have the sloped optional, I would be very greatful. Even though the angle doesn't seem incredibly steep, I am very worried about being barred from using a brilliant keyboard simply because of ergonomic reasons.
Could you please embellish on why you want the angled slope?
Offline AKmalamute
  • HHKB Scrub
« Reply #113 on: Thu, 24 July 2014, 15:53:52 »
a slight angle is what every one wants/expects, so it will be more marketable.
 Having said that, a few coworkers have their under-desk kbd tray set to invert the angle. Maybe for the GB, the same could be accomplished by having the case have a matching set of holes so the PCB can be reversed? Still a slight angle, but then the feet would be *toward* the user ... achieving hjkl's desires ... and no doubt a few others' as well.
HHKB-lite2, Dvorak user
« Reply #114 on: Thu, 24 July 2014, 17:32:37 »
I definitely second this suggestion. Great idea.
Offline Matias
    • http://matias.ca
« Reply #115 on: Thu, 24 July 2014, 21:37:34 »
You're mostly correct.  Long answer below...  (and see attached)
The switches are all the same over the entire keyboard.
The arrow keys use 0.75x1u keycaps. Because of the tighter spacing on the nearest & farthest sides, the keycap skirts are shorter -- which necessitates the case being a little higher there, to fill the gaps. Otherwise the switches would be exposed.
The farthest edge of the keycap is your point of reference for feeling where the arrow keys are. Because of the shorter skirts, that edge would not be high enough to feel -- so we fix it by using the row-4 keycap instead. It's just a little higher but easy to find by touch.
We actually did quite a lot of user testing on this. The R4 cap tested best for comfort and ease of acquisition.
Short answer...  It's designed correctly. You don't need to worry.
72381-0
« Last Edit: Thu, 24 July 2014, 21:41:24 by Matias »
Offline Matias
    • http://matias.ca
« Reply #116 on: Thu, 24 July 2014, 22:05:00 »
The slight slope is there solely to accommodate thickness of the fold-out legs when they are folded in.  The only way to get rid of the slope is to get rid of the legs.
Also, most people expect a little bit of an angle.  If the desk is high, a little positive tilt helps your wrists accommodate that height.
If your desk is low (or has a keyboard tray that's lower), then flat or negative tilt is better.  The more high-end keyboard trays can be angled to eliminate the positive tilt of most keyboards.
Unfortunately, that won't work with this design.  The case is not symmetrical, so you can't rotate the PCB.  See below for what I mean.
If you REALLY want it flat, then the only option would be to do a one-off CNC'd plastic one just for you, but that would cost several hundred dollars to do.
72384-0
« Reply #117 on: Fri, 25 July 2014, 02:40:48 »
Thanks Matias. Excellent explanation and illustrations as usual.
« Reply #118 on: Fri, 25 July 2014, 06:44:59 »
Another vote for the ability to swap backspace into the position above the Enter key. HHKB has spoiled me to this, and it's available via a DIP switch setting on my KUL ES-87.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #119 on: Fri, 25 July 2014, 08:01:43 »
Agreed. I've fallen prey to this same layout.
Offline Matias
    • http://matias.ca
« Reply #120 on: Fri, 25 July 2014, 09:04:06 »
Okay, will add it.
At this rate, we're going to have more DIP switches than keys...   :rolleyes:
Offline geniekid
« Reply #121 on: Fri, 25 July 2014, 09:27:13 »
Okay, will add it.
I'm more or less vocalizing support for layout features that I enjoy.  In actuality, I would buy this no matter what tweaks were available.  My thinking goes like this - unless every single feature I want is supported, I'll still be trying to replace the controller with a fully programmable one.  Obviously I can't speak for anyone else, but the primary draw of this keyboard for me is the physical layout.
« Reply #122 on: Fri, 25 July 2014, 09:35:55 »
;D
Offline Matias
    • http://matias.ca
« Reply #123 on: Fri, 25 July 2014, 09:58:20 »
;D
My god, I really hope that's a Photoshopped image...
« Last Edit: Fri, 25 July 2014, 10:02:30 by Matias »
« Reply #124 on: Fri, 25 July 2014, 10:12:24 »
Haha, yeah that's my terrible photoshop hack.
Offline Matias
    • http://matias.ca
« Reply #125 on: Fri, 25 July 2014, 11:02:11 »
Okay, will add it.
Okay, thanks.
And my goal with this project is to try to keep things basic as possible, but facilitate customization for people willing/able to do their own mods.  If enough people want something, I'll add it -- but I'm trying to avoid something that ends up looking like this...
http://simpsons.wikia.com/wiki/The_Homer
http://danicast83.wordpress.com/2013/09/16/the-homer
« Reply #126 on: Fri, 25 July 2014, 11:56:23 »
It's just my opinion, but having multiple options for the function key is the most important thing for the dip switches to have since there's no way to change it in software. Other options are great and it's definitely more convenient to have them in hardware, but if it comes down to it, at least everything else can be reconfigured with something like autohotkey or registry changes.
Offline Matias
    • http://matias.ca
« Reply #127 on: Sun, 27 July 2014, 03:02:53 »
Okay, I'm leaving for China in 4 hours, and will be working on the 60% keyboard while I'm there.  I should have a mockup done by the time I return.  Will post photos as soon as I have them.
Thanks to everyone for their feedback and suggestions...
Offline blackbox
« Reply #128 on: Sun, 27 July 2014, 05:03:14 »
Cant wait to see the pictures!
The LAN table!
Offline Belfong
« Reply #129 on: Sun, 27 July 2014, 08:33:03 »
Sorry for being late but YES, definitely interested:
Mac and ANSI and Clicky switch!
Option C because you said that Fn and arrow keys are able to simulate Home, End, Page Up and Page Down (but I'm ok with B also)
And Fully Assembled please..
« Last Edit: Sun, 27 July 2014, 08:43:39 by Belfong »
« Reply #130 on: Sun, 27 July 2014, 11:38:59 »
Matias, please change my order to option C. I hope it's not too late to change the order. I have edited the post that contains my order.
Offline geniekid
« Reply #131 on: Sun, 27 July 2014, 11:43:42 »
I think this project is still purely in the Interest Check phase.
Offline spiceBar
    • ChessTiger.com
« Reply #132 on: Mon, 28 July 2014, 05:02:00 »
;D
 LOL :)
User's manual
Volume 1/12: DIP switches 1 to 4 (324 pages)
« Last Edit: Mon, 28 July 2014, 05:04:12 by spiceBar »
Offline zxz
« Reply #133 on: Tue, 29 July 2014, 12:32:04 »
Sounds interesting, will there be a usb hub like on the mini pro?
PC
ISO
Full Cluster-Option A
Quiet Switches
Fully built
Offline Nuum
« Reply #134 on: Tue, 29 July 2014, 13:35:58 »
I'd be interested in:
Keycaps:
PC
ISO
Nav Cluster:
Option A
Switches:
Clicky ALPS
Pre-Assembled or Kit:
Both
And I would actually prefer it, if the spacebar would be centered on F and J.
Offline Matias
    • http://matias.ca
« Reply #135 on: Tue, 29 July 2014, 14:52:26 »
Yes, have not posted the GB yet, but hope to do that soon.
No hub on this one, but you can certainly plug it into one.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #136 on: Tue, 29 July 2014, 18:25:15 »
interested. this might be a really good board for my grandmother. she has small hands and a bad back. i think the wider spacebar and modifiers might really help her.
Offline luckynet
« Reply #137 on: Sat, 09 August 2014, 10:28:25 »
so any new update?? imma presume matias is gonna settle the work on the matias ergo pro first before publishing a group buy for the 60% board?? anyone here preordered the ergo pro??
Realforce 104U - HHKB Pro 2 dental band - HHKB Pro 2 Hasu's bluetooth controller - CM novatouch silent mod - Royal Kludge Topre clones
Filco Magestouch 2 Brown - Duckyshine 9008s Brown - QFR white - Plum MX 96 Blue - KBT Race Red - SS 7G Black - Poker blue - ducky shine 69
IBM Model M SSK
Matias quiet pro - V60 matias clicky
Offline Matias
    • http://matias.ca
« Reply #138 on: Sat, 09 August 2014, 20:21:53 »
We'll be getting PCB and mounting plate samples for Option C in a few days.  If no problems, we'll then do Option A samples.  Probably will not start on the case drawing until after the GB is complete.
Been a little busy with the Ergo Pro and another project, but the 60% is still proceeding as planned.
« Last Edit: Sun, 10 August 2014, 14:03:46 by Matias »
Offline dante
« Reply #139 on: Sun, 10 August 2014, 17:23:01 »
Originally I was not interested in this, Matias.  However - I could regain interest if a certain criteria could be met...
Most of these mini keyboards are anywhere from 1.25"-1.6" thick.  I know you can get a wrist rest for more comfort - but some of us prefer to go without that for various personal reasons.
Is there anyway to make this much thinner than usual?  Say 1.00"-1.10" thick?  The upcoming Ducky Mini showcases this as a feature on theirs "The lowest we could possibly lower our switches."  Having a thinner keyboard could possibly wrangle in some additional purchases from folks who have shyed away from Mechanical Keyboards because it's like typing on a phone book (Blame Apple and their excellent Aluminum keyboards for this.)
Offline Matias
    • http://matias.ca
« Reply #140 on: Mon, 11 August 2014, 00:22:10 »
It's already that thin now.  I just measured it...
Distance from the bottom of the case to the top of the Row1 keycap is 27.5mm or 1.08".
Yes, we're well aware of this.  Not everyone is into the classic styling + hubs.  That's why our 60% is going aggressively thinner and more minimalist, in size and styling.
Offline RED-404
« Reply #141 on: Mon, 11 August 2014, 01:32:09 »
Me reading this.  :) :D ;D ^-^ ^-^ ^-^ ^-^ ^-^ ^-^ ^-^ ^-^ ^-^ ^-^ ^-^ ^-^  :thumb:
« Reply #142 on: Mon, 11 August 2014, 01:44:59 »
I agree with dante. It's easier to raise a keyboard than it is to lower it. It's like salt in food..
What row is "Row1"? Space row, shift row, enter row, tab row, or number row? Can you please share the measurements for the tallest point of the keyboard and the lowest point of the keyboard?
Looking forward to seeing the group buy soon. Any idea of how much this will cost, or is this still too early to tell? Ballpark figure of course..
Offline Matias
    • http://matias.ca
« Reply #143 on: Mon, 11 August 2014, 02:34:58 »
Spacebar and Shift key rows are Row1 height = 27.5mm from keycap tip to bottom case.
Numbers/Backspace row is Row4 height = 28.5mm from keycap tip to bottom case.
The supports for foldout legs will protrude from the bottom about 8 or 9mm, in the two spots where the legs are.
It's too early to know the cost, but I'd guess in the $100 to $150 range, depending on how many people buy.
Offline Matias
    • http://matias.ca
« Reply #144 on: Mon, 11 August 2014, 02:50:55 »
Further to my previous post, and to give you a better idea of how slim it will be, below is a screen snap of the mounting plate...
We're going right to the edge of what's possible.  You can see (especially near the Nav Cluster) that it's as slim as it can be.
74093-0
Offline nuclearsandwich
« Reply #145 on: Mon, 11 August 2014, 03:46:54 »
How is the plate going to be mounted? Or is this going to be a caseless bent stainless build?
Offline jacobolus
« Reply #146 on: Mon, 11 August 2014, 03:47:01 »
This is the plate for use with MX switches outside the bottom row? How do those stabilizer holes work?
Offline Matias
    • http://matias.ca
« Reply #147 on: Mon, 11 August 2014, 06:11:31 »
Yes, and stabilizer holes are for hooks to hold the stabilizer (Costar style).  Four holes are shown, to support separate stabilizers for ALPS and Cherry.
See below for more detail (ALPS only shown)...
74099-0
Offline Matias
    • http://matias.ca
« Reply #148 on: Mon, 11 August 2014, 06:17:34 »
It will sit on posts, and will be held in place by screws that screw into the bottom case.  See IC for case drawings...  http://matias.ca/60
Offline jacobolus
« Reply #149 on: Mon, 11 August 2014, 06:33:11 »
Interesting. So I take it you’ll be selling the plastic stabilizer inserts/clips and bent wires compatible with MX-mount keycaps as well? Are you willing to sell just the stabilizer parts (both MX and Alps versions) in bulk, separately from this keyboard? And if so, how soon will those be ready for sale?
How well do they work compared to standard Alps stabilizers or standard Costar-style stabilizers?
I ask partly because there are several types of Alps keycaps that use MX mounts for the stabilizer inserts. It looks like this might be the first keyboard compatible (by swapping out the stabilizer parts) with both those and standard Alps keycaps.
