Author Topic: recommend a new keyboard?  (Read 10088 times)
Offline dv8omega
« on: Sun, 06 July 2014, 13:25:24 »
in the market for a tk/tkl keyboard or even a 60%. what could you guys recommend. so far i have my eyes set on ducky shine 3 tkl but its a little out of my budget. i do want something with LED backlighting. abc or pbt keys dont matter
Offline Pacifist
  • on hiatus
Re: recommend a new keyboard?
« Reply #1 on: Sun, 06 July 2014, 13:26:02 »
ducky zero shine
qfr-i
« Reply #2 on: Sun, 06 July 2014, 13:33:49 »
KUL ES-87 is probably the best stock TKL right now
Offline Pacifist
  • on hiatus
« Reply #3 on: Sun, 06 July 2014, 13:34:27 »
no backlit
Offline epzy
  • HHKB Fiend
  • ded
« Reply #4 on: Sun, 06 July 2014, 13:37:13 »
Poker 2. :)
Offline dv8omega
« Reply #5 on: Sun, 06 July 2014, 13:52:56 »
couldnt find ducky zero shine in a tk/tkl :/
do poker 2 come with LED i dont have the time or skills to solder on LEDs myself.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #6 on: Sun, 06 July 2014, 14:19:05 »
Yes, the Poker 2's with ABS keycaps comes with LEDs.
Offline dv8omega
« Reply #7 on: Sun, 06 July 2014, 14:36:02 »
where can i find one with abs
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8 on: Sun, 06 July 2014, 14:57:13 »
Amazon.co.uk & mechkb.com.
Idk where else they are being sold. :/
« Reply #9 on: Sun, 06 July 2014, 15:00:47 »
qtan?
Offline dv8omega
« Reply #10 on: Sun, 06 July 2014, 20:14:38 »
mechkb's shipping cost are killing me :/ and uk's conversion is killer
Offline deltuhhh
« Reply #11 on: Sun, 06 July 2014, 21:22:40 »
I also vouch for the Ducky keyboard.
Offline dv8omega
« Reply #12 on: Sun, 06 July 2014, 21:43:23 »
how customizeable is the ducky
Offline deltuhhh
« Reply #13 on: Sun, 06 July 2014, 21:44:51 »
What do you mean?
Offline dv8omega
« Reply #14 on: Sun, 06 July 2014, 21:51:15 »
What do you mean?
keycaps, maybe even the case
Offline Smasher816
  • HHKB Master
« Reply #15 on: Sun, 06 July 2014, 21:53:39 »
I believe it's a standard layout so you can put whatever keycap sets you want on it. Keep in mind there are not that many sets for led keyboards. However, many people can enjoy the "underglow" effect of opaque keycaps.
Offline dv8omega
« Reply #16 on: Sun, 06 July 2014, 21:55:02 »
noted.
Offline deltuhhh
« Reply #17 on: Sun, 06 July 2014, 22:26:12 »
Yeah, customizable keycaps for sure. I'm pretty sure you can customize the case as well though I'm not sure. I haven't seen much Ducky Shines with cases.
Offline duzeyao
« Reply #18 on: Mon, 07 July 2014, 02:20:26 »
I suggest Ducky 2087s and CMStorm QFR-i, too. They both were solid built and the brands have very good reputation.
你绝版的婊子妈坟
Offline dv8omega
« Reply #19 on: Mon, 07 July 2014, 23:16:05 »
would you rather get a ducky 2087s or a QuickFire TK. which would last long and will allow for switching keys, and maybe a case
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #20 on: Mon, 07 July 2014, 23:35:14 »
Try and find an aold(er) KC 84/87
The older ones have Cherry switches. The newer ones are Kalih. But there are still Cherry ones floating around.
Offline Fragil1ty
  • Abre los ojos.
« Reply #21 on: Tue, 08 July 2014, 06:31:25 »
If you're in the market for a new keyboard, I'd go for a 75% over a 60% I think a 60% is that transition after you've had a 75% for quite some time and you think, "Hm, I want something more niche/minimal/desksaver" or whatever and that's when you go for said 60% board.
I'd advise the Noppoo choc mini or the Filco TKL for start boards (tkl and 75%).
你搞砸了
Offline Quardah
    • DeliTech
« Reply #22 on: Tue, 08 July 2014, 07:18:46 »
Poker II is fully dual-layer programmable, and all ommited keys like printscreen or insert or end or arrow keys are on the FN layer already ready to use.
Poker II is 60% available in Red Black Brown Blue.
Poker II has backlite.
Poker II has standard ANSI or ISO layout.
Poker II can be customized as you wish. Has standard plate mount for easy switch swapping.
Poker II is best Poker. Poker II is king of 60%. Poker II honor famiry. Praise Poker II.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline dv8omega
« Reply #23 on: Tue, 08 July 2014, 20:54:28 »
i guess ive narrowed it down to 3 keyboards. switch type is between brown n blues.
which should i learn towards to?
ducky zero shine tkl
cooler master quick fire tk
noppoo lolita 87
« Reply #24 on: Tue, 08 July 2014, 21:16:24 »
I personally would choose the Ducky.  TK and Noppoo have ... odd layouts (to me, anyway).
Offline dv8omega
« Reply #25 on: Tue, 08 July 2014, 23:31:39 »
going with ducky. now to decide between browns n blues. which would be good for first timers?
Offline deltuhhh
« Reply #26 on: Tue, 08 July 2014, 23:56:13 »
Great choice! I'd just say Browns since many people like them. You can always return it and grab another one if you don't like the switch.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #27 on: Wed, 09 July 2014, 00:02:56 »
^^ For the price, it's hard to beat a kul-87 if you're looking for a tkl, good luck. :)
Offline dv8omega
« Reply #28 on: Wed, 09 July 2014, 00:07:57 »
is the kul that much better than ducky? and where is the best place to find a kul
Offline digi
  • elite af tbh
« Reply #29 on: Wed, 09 July 2014, 00:14:18 »
If you like MX Clears the KUL has an option to get them, it has PCB mount stabs which I'm OCD about but might not be that big of a deal to others. I believe Elite Keyboards & Mechanical Keyboards are the main North American distributors. I just received mine today.
Offline xuanwumen
  • * Commercial Vendor
    • EZKB
« Reply #30 on: Wed, 09 July 2014, 01:20:23 »
http://www.aliexpress.com/item/ducky-2087S-TKL-tenkeyless-gaming-mechanical-keyboard-blue-backlit-cherry-mx-switches-brown-ducky-87-LED/1926011870.html
Ducky zero 2087S LED version.
NIZ KEYBOARDS VENDOR
« Reply #31 on: Wed, 09 July 2014, 02:00:51 »
Again personally I'd say blues.
Browns just seem gritty to me, but then a lot of people do like browns.
But the blues, with the excited little clicks, are quite different from the rubber domes you are probably accustomed to.
Just as long as you are not working somewhere near other people who might be annoyed by the high-pitched clicking.
Offline dv8omega
« Reply #32 on: Wed, 09 July 2014, 09:21:31 »
just saw Keycool II 84. soo now its between ducky zero shine tkl and Keycool II 84  D: .
still stuck on deciding between blues and browns...
« Last Edit: Wed, 09 July 2014, 10:35:32 by dv8omega »
Offline TBone
« Reply #33 on: Wed, 09 July 2014, 11:03:06 »
I love my KUL ES-87. I believe unless you plan on getting an aftermarket case, it is the best TKL on the market right now besides the lack of switch options. Maybe Filco rivals it in build quality and non-modded stabilizers if you prefer Costar.
But it has plate mounted stabilizers. I just modded mine yesterday. PCB mounted stabs clip on to the PCB, KUL ES-87's stabs mount to the plate. Which kind of sucks because you have to desolder the switch to do the Cherry Stabilizer mod.
Once you do the Cherry Stabilizer Mod to make the stabilizers feel more solid (like Costar stabs), I have no doubt it is my favorite board on the market right now. I prefer a few keys to have led's (CAPS, SCROLL LOCK) rather than all of them anyways. Dat underglow  :D
Offline dv8omega
« Reply #34 on: Wed, 09 July 2014, 14:51:20 »
oh the choices D:
Offline Sagii
  • Time to bust some nails
« Reply #35 on: Wed, 09 July 2014, 16:47:31 »
oh the choices D:
Ey, tell me 'bout it. I came here one and a half month ago, looking for my ultimate gamerz keyboardsszz.. Tell you what, after a month of trying to decide, I ended up with a freakin' HHKB Pro 2. You better pull the trigger soon, or ya gonna end up spending quite the chunk of money :D :)) (not that it's a bad thing)
Offline dv8omega
« Reply #36 on: Wed, 09 July 2014, 19:50:53 »
oh the choices D:
damn :XXX im entirely broke. dropped 1k on my pc so far..... keyboard is the last thing on my list
Offline EvillePanda
« Reply #37 on: Wed, 09 July 2014, 20:25:36 »
I've bought two keyboards in the last six months and planning on at least three more purchases.  It never ends.  My first was an mx blue TECK, then an ergo dox with clears.  I can't say for sure, but I think I like the clears better.  I need more time.  I hate linears.  I can say that for sure.  Tactile is where it's at for me so far.  I still need to try Topre.  It's all about personal preference.  And I do game with blues and no problems.  Of course, I don't play FPS games with it.
Offline dv8omega
« Reply #38 on: Wed, 09 July 2014, 20:29:04 »
you think browns would be better for gaming? fps and rts
« Reply #39 on: Wed, 09 July 2014, 20:30:16 »
Welcome to Wallethack!
Offline EvillePanda
« Reply #40 on: Wed, 09 July 2014, 20:35:01 »
Linears have the least resistance.  My boyfriend does a lot more PC gaming than I do and he finds the reds are too light.  He often presses them without meaning to.  I've never used browns, but I'm finding blues too light, so I haven't even tried browns.  If you can, test how heavy the switch is.  If you can rest your had on the key and press it, you might go with a clear or a linear black.
Offline EvillePanda
« Reply #41 on: Wed, 09 July 2014, 20:36:05 »
There are worse hobbies/ways to spend money.  Though between keyboards and my knitting, it's amazing I have any cash.
Offline dv8omega
« Reply #42 on: Wed, 09 July 2014, 20:39:42 »
i mean im pretty open to use any switch, im coming from rubber domes so... anything is a big improvement.
« Reply #43 on: Wed, 09 July 2014, 20:40:32 »
One hobby is bearable, two is fatal!
I have three :eek:
Offline dv8omega
« Reply #44 on: Thu, 10 July 2014, 00:31:19 »
ahhh put in an order for ducky shine zero tkl brown switches :X dont change my mind anymore!
Offline Sagii
« Reply #45 on: Thu, 10 July 2014, 03:06:20 »
I have three :eek:
Dude, try and merge gaming (aka computer parts), playing the guitar (buying guitars), and now keyboards as well.. doesn't end up well :)) luckily all of those hobbies make you spend a large chunk of money at once, then it goes several moths before you buy something again. Scary part is that I haven't really started the keyboard hobby yet!
Okey, back on topic. When it comes to switches i found that red was too light. I thought it was because they were linear that i didn't like them,  but then I tried blacks and i really liked those. Never tried any other switches. As for topre, I'm not sure wether I like it or not, haven't decided yet!
« Last Edit: Thu, 10 July 2014, 03:08:55 by Sagii »
Offline Oobly
« Reply #46 on: Thu, 10 July 2014, 03:50:31 »
That's a nice board :)
Browns are a good "starter" switch. Gives a good reference point for deciding the perfect switch for you (whether you want more tactility or less, stronger springs, etc).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #47 on: Fri, 29 August 2014, 21:26:11 »
HHKB type S
