Author Topic: Keycap size standard?  (Read 9376 times)
Offline victor
« on: Tue, 08 July 2014, 18:33:39 »
Hi I'm a new comer here so pardon me if I'm asking the obvious... and any reference or link would be appreciated.
So my question is if there is a standard size for keycaps, or it depends on the brand or switch?
The reason why I'm asking is because I'm considering getting some custom keycaps for my CM QuickFire Rapid keyboard which uses Cherry switches. Apart from making sure the base ('+') is Cherry compatible, I wonder if the size of the key is a concern so they won't be too large to hit each other.
I kind of expect there is more or less a similar size at the base of the keycap because it appears to me there is just one type of plastic keycap puller (a ring with 2 "hooks"). But I'm not sure about the top part.
Got a CM QFR, now switching between KBT Pure.
Re: Keycap size standard?
« Reply #1 on: Tue, 08 July 2014, 19:01:48 »
There is a standard size.  I don't know exactly what it is, but every keycap set I have matches that standard so it's never been a concern.
Any standard set (e.g. US ANSI) should fit a QFR no worries.
There are also wire keycap pullers like this.
Offline deltuhhh
« Reply #2 on: Tue, 08 July 2014, 19:22:03 »
I believe there is a standard size to keycaps. I've seen keycaps made for Duckies on QFRs before so you should be fine. Just make sure that the keycap(s) are made for Cherry MX switches.
Offline victor
« Reply #3 on: Tue, 08 July 2014, 19:33:13 »
I've seen some nice keycaps stating something like "KBT Poker"- or "Ducky"- MX switch so I suppose they will fit fine on my QFR. I understand that some vendors might change the length of the space bar or right shift keys to fit in more keys for more compact form factor, so for that I'll probably be careful with.
Offline deltuhhh
« Reply #4 on: Tue, 08 July 2014, 19:38:42 »
Right! I forgot about the spacebar! Yeah, there are like 3 different sized spacebars or something like that. So if your spacebar doesn't fit, don't panic.
« Reply #5 on: Tue, 08 July 2014, 20:02:52 »
Some sets are made to match a particular keyboard.
Poker has a smaller layout, and thus less keys.  A Poker set would not suit a Ducky, for example.
Conversely a Ducky set would include 87 or 108 keys to suit Ducky keyboards.  For conventional layout keyboards such a set would fit most keyboards.
When a keyboard has non-standard space bar or modifiers, that is when the problems start.
Offline victor
« Reply #6 on: Tue, 08 July 2014, 20:32:02 »
Makes sense. When you say "fit"/"match" did you mean the number of keys, except the shape of spacebar and modifiers? E.g. A Ducky set won't "fit" a Poker because there are more keys in the set?
If so, let's say if I just aim at replacing the "squarely" keys such as the alphanumerics (1-0, a-z) and some punctuation marks, the keycaps would work cross-keyboards?
« Reply #7 on: Tue, 08 July 2014, 21:20:35 »
The poker has a fairly standard layout, not sure about the space bar though.  A Ducky set would probably fit, but you'd have a lot of keys left over.
To replace just the alphas, you need to consider whether the keyboard and keycap set are ANSI or ISO, US or "foreign" layout, and qwerty or Dvorak or Colemak.
Otherwise, pretty much yes.
Offline victor
« Reply #8 on: Tue, 08 July 2014, 22:02:19 »
Ah good call. Thanks! My QFP is a typical US qwerty keyboard.
Offline Xenderwind
« Reply #9 on: Wed, 09 July 2014, 01:54:10 »
Didn't really read most of the thread but I saw you say both QFR and QFP.  The QFR is fine but the quickfire pro looks like it has some weird layout that will be very hard (if not impossible) to find replacements for all the keycaps.  It uses some weird tsangan kit mixture but with a 6.0 spacebar (unless my math is wrong).
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline Oobly
« Reply #10 on: Wed, 09 July 2014, 03:09:17 »
The QuickFire Rapid has a completely standard 87 key (TenKeyLess or TKL) layout, so any standard ANSI set with 87 or more keys will fit just fine. In other words, look around for a set you like and it will almost certainly fit your board.
The QuickFire Pro on the other hand has a non-standard bottom row and it will be almost impossible to find a complete replacement set of keycaps for it.
A few things to keep in mind with keycaps:
1. There are different "profiles", with different keycap heights, surface angles and types of "dent" in the top. Cherry profile is quite low, with different angles per row and "cylindrical" dents. OEM profile is the type that usually comes on a board and is higher than Cherry, but has similar angles and cylindrical dents. DCS is a profile made by a company called Specialised Platics (SP) and it's similar to Cherry profile, but with a steeper angle on the bottom 2 rows. DCS also doesn't have the "crossbar" pieces inside the caps, which is important if you want to add orings (will explain this later). DSA is quite low profile, with no angles on the caps (so any cap can fit on any row) and spherical dents. SA is tall profile with different angles and spherical dents. OEM profile caps can differ slightly between manufacturers / brands.
2. There are different layouts, with the most common being US ANSI. In Europe you will find ISO layout is the more common, it has a taller "Enter" key, often "L" shaped and shorter left shift key with <> key between it and "Z". Then there are different language charactter layouts, for German they use QWERTZ, for French, AZERTY, etc. Nordic keyboards also have keys for ÖÄÅ, etc and symbols in different places. A US ANSI layout board is easiest to find aftermarket caps for by far. There are also two main bottom row layouts, one with 7x spacebar and 1.5x Ctrl and Alt with 1x Winkeys (often referred to as Tsangan, less common) and one with 6.25x spacebar and all 1.25x modifiers (sometimes referred to as Moogle, but it's a lot more common than Tsangan, so is often just called standard ANSI).
3. Keycap materials and thickness. There are 3 main materials that keycaps are made from, ABS, PBT and POM. ABS is the most common and boards usually come with thin ABS caps. Thicker keycaps have a higher quality feel to them and often actually are higher quality. The material is less important than some people here will be inclined to tell you, but it does change the feeling of the caps. ABS gets smooth quite quickly and can feel "sticky" when smooth. PBT wears more slowly and feels "drier". POM also wears slowly but feels more "slick". POM is densest, then PBT then ABS, so POM caps will be heaviest. Heavier keycaps tend to feel higher quality. Well made thick caps in any material are very nice to use.
4. Keycap manufacturers. GMK makes excellent, high quality caps, as does BSP. KBC and TaiHao make reasonable caps, but not up the standard of GMK et al. SP caps fit somewhere in between. Vortex make some good sets and some just okay sets, I think some of their sets are actually made by KBC. Their latest doubleshot PBT sets are apparently quite good, in a profile similar to Cherry. There are other makers, but these are the main ones.
5. Legends. The way the letters are put on the caps. Pad printed are printed onto the surface of the caps and are raised and can wear away relatively quickly. Laser etched legends are set into the surface a bit, laser foamed / printed stick out a touch. These are tougher than pad printed. Dye sublimated (dyesubbed) don't change the surface at all, but are dyed into the material of the cap. Also durable, but can be a little fuzzy. Also can ony be done in a darker colour than the cap itself and often used in ly on PBT material caps. Doubleshot is where they use two different colours of plastic to make the keycap in two stages, first one colour is molded to make the legends, then the main keycap material is molded around that. More expensive to make, but definitely the best type of legends.
So, thick doubleshot or dyseubbed Cherry profile keycaps made by GMK or BSP are VERY good, pad printed thin ABS OEM profile made by some random company.... not so good.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #11 on: Wed, 09 July 2014, 05:18:30 »
Unless it is the ISO version of the QFR ;)
Offline Oobly
« Reply #12 on: Wed, 09 July 2014, 07:55:09 »
See point number 2.
Offline victor
« Reply #13 on: Wed, 09 July 2014, 18:47:35 »
Thanks Oobly for the wonderful list of things to note. Very informative and makes me realized there is so much to learn. I like the way you described the lengths of the bottom row keys (7x, 1.5x ...etc). In that case those character keys would be 1x, right?
Just to be clear mine is QFR instead of QFP. Made a mistake but didn't know it actually referred to something else :)
Yes indeed the pro version often changes the bottom row. I'm looking for a KBT Pure (anyway wanting to sell it can let me know) now and noticed the pro version adds more keys by shrinking the spacer bar and right-shift.
I've seen some people having a different color for a different set of keys, e.g. grey for the character rows except the modifier keys, black for the spacebar, ...etc. I guess they must have bought different sets (or perhaps just a few keys) to mix & match. Really creative there.
