Author Topic: What do you reprogram your keys to be?  (Read 2245 times)
Offline Jixr
« on: Wed, 09 July 2014, 14:07:15 »
Hey everyone, I was curious to see what other peoples keyboards are set to using macros, programs, etc.
For Example,
On my full size keyboard at work ( autocad useage )
my num lock is programed to be always on, and the  'num lock' key itself acts like a delete key
my tilde key is programed to 'U'
F5-12 are media keys, play pause stop, next, vol +/-
Num pad + key is a backspace
Num pad * is ' and shift+/ is " ( for entering feet and inches easier )
swapped control and windows keys
Share your weird keyboard layouts below!
Re: What do you reprogram your keys to be?
« Reply #1 on: Wed, 09 July 2014, 14:08:47 »
My keyboard is stock but the buttons on my G700s are programmed to autocad commands :D
Offline Jixr
« Reply #2 on: Wed, 09 July 2014, 14:14:54 »
 I use a razer naga epic at work, I have it set up where I can work all day and not have to touch the keyboard one bit.
I also have my autocad commands to be set up in an FPS layout
for example,
s = extend
ss = line
sss = pline
and pretty much the only keys I have to use are qwerasdfzxc, so I always have a hand on the keyboard and one on the mouse, ultra efficiency!
Offline Battou62
« Reply #3 on: Wed, 09 July 2014, 14:20:06 »
Is this really necessary with aliases and right click repeat last command?
« Reply #4 on: Wed, 09 July 2014, 14:30:28 »
Its what works best for me, everyone is different.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #5 on: Wed, 09 July 2014, 15:38:54 »
Tenkeyless AT Model F
RCtrl and Caps both activate a layer which has:
Up/down/left down arrow - volume up/down, next/prev track
Backslash - mute
Backspace - print screen
Esc - system sleep
Num row 1 to plus is F1 thru F12
WASD are arrow keys
Either shift is caps lock
I also have Shift+Shift mapped to Caps Lock regardless of the active layer.
I was wondering about a 60% board at one time which is why I did the WASD and Fn keys, to try it out, but I never use them.  I cannot live without the dedicated navigation cluster.
Offline intelli78
« Reply #6 on: Wed, 09 July 2014, 15:47:17 »
It varies depending on the keyboard, but universally, I reprogram backslash to backspace, Ctrl+backslash to backslash, and backspace to forward delete.
Offline JPG
  • Model F is my new passion!
« Reply #7 on: Wed, 09 July 2014, 16:05:08 »
On my F-122 I do:
capslock = function for layer1
Layer1:
u = pagedown
i = uparrow
o = pageup
h = home
j = leftarrow
k = downarrow
l = rightarrow
; = end
I also configure a key on the left to be escape and one to be play/pause. I did other mappings on the left but never use them.
I am in LOVE with my function layer, it's so effective!
Offline Jotokun
« Reply #8 on: Wed, 09 July 2014, 16:26:32 »
On my Model M Soarers I have right alt as a window key, and right Ctrl as an Fn key. Pressing Fn+Ctrl or Fn.+Caps Lock will swap Ctrl and Caps lock. Fn+Print Screen is mute, Fn+Scroll Lock is Volume Down and Fn+Pause is Volume Up. Fn+Space switches hjkl to arrows and Fn+h/j/k/l acts like a single press of an arrow key, although I found myself using that much less than I thought. Fn+Esc is sleep.
On my F, I don't have any layers. If I need extra functionality, I just map it to one of the extra keys.
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline orihalcon
« Reply #9 on: Wed, 16 July 2014, 19:49:33 »
For use with macs, remapping Alt to the apple/command/gui key is a must for me.
Offline Zephitos
« Reply #10 on: Thu, 17 July 2014, 06:00:43 »
now.
capslock -> Win
in number layer,
m -> 0
j -> 1
k -> 2
l -> 3
u -> 4
i -> 5
o -> 6
7 -> 7
8 -> 8
9 -> 9
p -> +
; -> enter
compatible tenkey pad
Inventory
22mini brown, twosome mini, fc300r mx red,
WTB/WTS : [WTB] IMSTO PBT R2
To do
Make LZ's B series, LZ-FE,
And Fuxxing  DrugER
« Reply #11 on: Thu, 17 July 2014, 06:49:27 »
I always make sure to have a hotkey that takes me directly to  zombo.com
Offline davkol
  •  Post Editing Timeout
« Reply #12 on: Fri, 18 July 2014, 03:13:10 »
I use Colemak including Caps Lock remapped to Backspace. When playing RTS games on my Noppoo Choc Mini, I swap Caps Lock and Control, i.e. Ctrl is next to the A key and Backspace in the corner Ctrl spot. I never use Caps Lock or the "hardware" Backspace key.
While I had a Kinesis Advantage, I remapped Caps Lock to AltGraph, because the default AltGraph placement was very inconvenient and Backspace was already present in a thumb cluster.
I had an Apple Aluminium International keyboard for a while too. The narrow Enter key was so horrible that I swapped backslash and Enter in software.
My ErgoDox layout looks like this (arrows are on the home row on Layer 2):
