Author Topic: What is the best wrist rest?  (Read 7602 times)
Offline Fragil1ty
  • Abre los ojos.
« on: Fri, 11 July 2014, 14:24:06 »
So I've only ever really owned one wrist rest in the past and it was made by Grifiti, it was okay, but before long, the sides started to peel away and what not, so that didn't last very long, link here; http://www.amazon.co.uk/Standard-Keyboards-Mechanical-Notebooks-MacBooks/dp/B004D8PYE2/ref=sr_1_1?ie=UTF8&qid=1405106452&sr=8-1&keywords=Grifiti+wrist+rest (I obviously bought the equivelant for the noppoo choc mini, so the smaller version).
I'm just wondering what would you recommend as a good quality wrist rest that can stand the test of time without wearing away and what not, i'd rather not get a wooden one, as over time, my wrists may stick to it and what not, i'd prefer a similar one to what I have now, but if wood is the way to go? then I guess that's the way I'll have to go then wont I?!
你搞砸了
Offline luisbg
Re: What is the best wrist rest?
« Reply #1 on: Fri, 11 July 2014, 14:28:30 »
A colleague has one made of leather that is really nice. I personally prefer not using a wrist rest.
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline Fragil1ty
  • Abre los ojos.
« Reply #2 on: Fri, 11 July 2014, 14:30:49 »
I'm the same really, I don't really use them, I guess it's just nice to have them if you do want to use one and what not.
你搞砸了
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #3 on: Fri, 11 July 2014, 14:37:10 »
I custom build leather wrist rests over in the Artisan subforum :)  I might be biased, but I designed them to be very high quality and so far customers have all been really happy with them.
http://geekhack.org/index.php?topic=51762
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
Offline Vanilla
  • 110% Snuggable
« Reply #4 on: Fri, 11 July 2014, 14:47:55 »
Yeah those grifiti wristpads are just oversized elongated mousepads....
The best wristrest in terms of durability in my opinion is 3M's gel leatherette.
I bought my 1st one in the office about 5 and half years ago and despite daily working hours use, it still looks brand new.
Recently bought one for the garage and the quality has not changed one bit although the bottom serial label has been tweeked a bit by 3M.
http://www.amazon.com/3M-Keyboard-Leathette-Antimicrobial-Protection/dp/B000WU4H5C/ref=sr_1_1?ie=UTF8&qid=1405107811&sr=8-1&keywords=3m+wrist+rest
Offline Lammie
« Reply #5 on: Fri, 11 July 2014, 14:50:10 »
The Grifiti's are alright for the price. But I find the surface a bit too large. Cutting off my blood in my wrist a bit..when typing
Topre Realforce 55g
Topre Leopold FC660C 45g
Matias Quiet Pro Mini
Cherry ML G84-4100LPAUS
Cherry MX Green QFTK
Model M Unicomp 103
Offline "Edgar Allen Pho is Dead."
  • formerly known as anoose
  • Member Since '11
Offline tigersharkdude
« Reply #7 on: Fri, 11 July 2014, 15:22:43 »
I prefer wooden pieces or other hard pieces. Im not a fan of the soft/gel wrist rests
Shameless plug
  • Member Since '11
« Reply #8 on: Fri, 11 July 2014, 15:31:00 »
Shameless plug
If I could get a dollar for every time I see this picture... I would be living next to Bill Gates
Offline E TwentyNine
    • Some of My Keyboards
« Reply #9 on: Fri, 11 July 2014, 15:35:10 »
If your wrist is on the rest while you're typing you're doing it wrong.
« Reply #10 on: Fri, 11 July 2014, 15:37:51 »
Shameless plug
Seeing how ive only had the full setup for a few weeks, I think you're off by about one hundred mil .. lol
Offline pasph
« Reply #11 on: Fri, 11 July 2014, 16:18:33 »
Highly reccomended
« Reply #12 on: Sun, 13 July 2014, 08:45:27 »
Highly reccomended
+50 for noko leatherworks
Offline Hypersphere
« Reply #13 on: Sun, 13 July 2014, 09:30:57 »
In order to prevent carpal tunnel syndrome it is best not to use a wrist rest when typing.
Offline ckar
« Reply #14 on: Sun, 13 July 2014, 09:56:36 »
Just use your desk surface as a wrist rest. Problem solved.
Offline FoxWolf1
  • 154
« Reply #15 on: Sun, 13 July 2014, 10:17:57 »
Custom is probably best, but if you want something off-the-shelf, 3-star from EK is quite nice.
Offline CaptLock
« Reply #16 on: Sun, 13 July 2014, 10:28:45 »
I never use one
« Reply #17 on: Sun, 13 July 2014, 21:29:26 »
I prefer my wood wrist rests to any other's I've used.  They're far more comfortable than gel or soft ones. Wrist rest is a misnomer though since I designed it as a palm rest.
« Reply #18 on: Sun, 13 July 2014, 22:24:49 »
Some people say a hard material like wood or metal or marble. But that's just ****ing crazy. It's called a wrist rest, not a wrist torture device. Go with something soft, but not too high. Feels good.  :)
« Reply #19 on: Sun, 13 July 2014, 22:29:17 »
I need to loan you one of the wood rests I've made or something.  They're far more comfortable than something soft and spongy since you rest your palms on them, not your wrist.
« Reply #20 on: Sun, 13 July 2014, 22:38:01 »
I definately rest my wrists on a wrist rest, not palms. Plus it often doubles as a soft buffer between my shins and my sharp-assed desk because I constantly have my legs up. I could never see making the switch, unless I got a really high desk I couldn't put my legs up on.
« Reply #21 on: Sun, 13 July 2014, 22:41:02 »
The most ergonomic way is to rest your palms. If you rest your wrists, something squishy feels better, but is worse for you.
