Author Topic: USB or PS/2 for New Unicomp  (Read 3971 times)
Offline skinnycow
« on: Sat, 12 July 2014, 14:07:47 »
Hi, just wanted to ask the experts here for advice before purchasing a Unicomp keyboard from the manufacturer (I'm looking  at the UNI0416 model, http://pckeyboard.com/page/Classic/UNI0416) This model comes in both USB and PS/2 versions, but I'm not sure which one to get.
I'm going to use it primarily for a Windows 98 gaming pc (only has a PS/2 port for a keyboard) I am setting up, but I'd also like to use it on more modern computers (ones that don't have a PS/2 port, only a USB port).
So my question, if I buy the PS/2 model, is it a simple matter of plugging the keyboard into a PS/2-to-USB adapter to get to work on a modern system? I'm guessing not, but I don't know anything about these interfaces.
Thanks for any help.
Offline Doyniish
  • Good you
    • Power Hour Playlists
Re: USB or PS/2 for New Unicomp
« Reply #1 on: Sat, 12 July 2014, 14:16:33 »
For your needs I would definitely go with the PS/2 model. PS/2 to USB adapters are so cheap and i've never really had any issues connecting an older board to a more modern machine when using one.
Offline Vanilla
  • 110% Snuggable
« Reply #2 on: Sat, 12 July 2014, 15:19:00 »
2nded for the ps/2 model.
I believe just like the model m, that unicomp board will need an active* ps/2 to usb converter however due to its higher power draw. A good proven one is the ziotek blue cube which is about $10 on amazon.
Offline skinnycow
« Reply #3 on: Sun, 13 July 2014, 09:29:15 »
Awesome, thanks for the advice. I picked up the ziotek adapter and the ps/2 model keyboard.
What is it about the older model M and unicomp that draw more power, is it the logic inside, or the LEDs, or something else? Just curious.
Offline Doyniish
  • Good you
« Reply #4 on: Sun, 13 July 2014, 11:24:19 »
I'm sure it's just the logic inside. Back in the day they drew more power through their keyboards or something.
Offline Jotokun
« Reply #5 on: Sun, 13 July 2014, 12:37:32 »
PS/2 would also let you hook it up to a Soarer's converter for any remapping or fn layer needs. If you need USB, I would highly recommend that route.
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline orihalcon
« Reply #6 on: Wed, 16 July 2014, 19:32:20 »
Agreed, PS2 is the way to go if one of your computers only has PS/2.  It can easily be converted with a PS2 to USB adapter, or you can go high end and use a Soarer's Converter for remapping and macros.
