Author Topic: Dell SK-1000R(S) - which switches?  (Read 4170 times)
Offline IBI
« on: Sun, 24 May 2009, 09:06:49 »
A Dell SK-1000RS has just come up on ebay UK here, it may well be earlier than or comtemporary to the AT102 as it doesn't have any windows keys. It looks a bit like the quiettouch but doesn't have the logo.
Looking around it appears as it might be the Silitek Space Saver SK-1000R, but unfortunately Dell's site doesn't list what switches it uses. It does list a 'Keycap pull-up force: 1 kg (2.2 lb) minimum" so I wonder if it might use Alps, but does anyone know for sure?
« Last Edit: Sun, 24 May 2009, 14:52:38 by IBI »
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline sandy55
Dell SK-1000RS - which switches?
« Reply #1 on: Sun, 24 May 2009, 11:05:50 »
Rubber dome over membrane
