Author Topic: WYSE K/B PCE INT'L #840362-01  (Read 2057 times)
Offline Faithfool
« on: Mon, 14 July 2014, 16:06:56 »
Hello
I have read on GeekHackWiki that this keyboard is "terminal-only".
...and I'm wondering if there is a way to make it work with my PC through ps2 cable.
Re: WYSE K/B PCE INT'L #840362-01
« Reply #1 on: Mon, 14 July 2014, 16:10:27 »
You can, with Soarer's WYSE Converter firmware and a Teensy 2.0 or similar, but using USB, not PS2
Offline Faithfool
« Reply #2 on: Tue, 15 July 2014, 03:26:02 »
so without this device I can do nothing? Its impassible to get in my country, and a bit too expensive.
« Reply #3 on: Tue, 15 July 2014, 13:09:31 »
You can use any ATmega 32u4 device, so one that's a bit more easy to get where you live, such as the arduino pro micro chinese clones would work as well, but are harder to set up.
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Wed, 16 July 2014, 09:45:39 »
czarek sells Teensy for €18 in Poland, see his website.
