Author Topic: How to access bios?  (Read 2832 times)
Offline Naweo
How to access bios?
« on: Mon, 14 July 2014, 16:59:38 »
Hello.
Motherboard: z77a-g45
I changed my Integrated Graphics from PGI to DVI by mistake and also disabled GT overclocking frequencies. Apparently my monitors are completely blackscreened.
At start, when my graphic card (nvidia gtx 560 ti) monitors were only black untill i reached windows, i tried to fix the problem with my integrated graphics monitor but I only just now realized it might have been because of disabling GY frequncy in overclocking setting.
Is there a way I can set my BIOS settings and OC to default, now that I can use my computer?
Thanks
Offline HPE1000
  • Keycap Paparazzo
Re: How to access bios?
« Reply #1 on: Mon, 14 July 2014, 17:01:58 »
Try spamming delete
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Mon, 14 July 2014, 17:07:32 »
I have seen different motherboards use F8, F5, Delete, and a couple others.  You could try going to the manufactureres website and checking for a PDF manual.  The info should be in there.
Edit:  Another option is to pull the motherboard battery out for a couple minutes and then put it back in.  That "should" reset the bios to all factory defaults.  Or like my board, there is a button on the motherboard specifically for reseting all bios settings.
« Last Edit: Mon, 14 July 2014, 17:09:06 by Melvang »
Offline Naweo
« Reply #3 on: Mon, 14 July 2014, 17:07:46 »
Doesnt work even after minutes, much longer than when it worked. :( I used to press delete. Its simpyl the issue that I cant get my monitors to work, any of them.
« Reply #4 on: Mon, 14 July 2014, 17:11:20 »
Any luck finding a manual on the manufacturer's web site?
Offline Xenderwind
« Reply #5 on: Mon, 14 July 2014, 17:11:50 »
There's certain ways to reset your bios/clear cmos depending on your mobo.  Some involve just taking out battery(and unplugging) and doing stuff like hitting the power button to make sure it doesnt have power.  Others involve jumping pins.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
« Reply #6 on: Mon, 14 July 2014, 17:16:52 »
Offline Xenderwind
« Reply #7 on: Mon, 14 July 2014, 17:18:10 »
the manual shows he should have a button on the back by his i/o plate or w/e thats called to clear cmos
Offline paicrai
  • mindblank
« Reply #8 on: Mon, 14 July 2014, 17:20:50 »
hax
for me when i start up a screen flashes that says press this for bios
THE FEMINIST ILLUMINATI
Offline Naweo
« Reply #9 on: Mon, 14 July 2014, 17:26:36 »
I found the CMOS button and held it for 5 seconds after the computer was unplugged. When I put it together, setting only keyboard, mouse and a monitor in alongside power, it just goes on and off all the time without bios errors.
Any solutions?
Thanks.
