Author Topic: [IC] RGB Modifiers in DSA Profile  (Read 4481 times)
Offline ntw
« on: Mon, 14 July 2014, 20:02:22 »
I have seen a lot of hype over the DSA Profile recently. I have tried one myself and really liked it. However there's not a set of RGB modifiers that is commonly available to complement these keysets (except matt3o's Granite set) and so I have decided to run a groupbuy on pimpmykeyboard.
This set will be made using ABS Doubleshot with White legends, consisting of 2x1.25 Control, 2x1.25u Alternate, 1x2.25u Shift and 1x2.75u Shift. The colors that I have chosen for Red is RA, Green is VCS, and Blue is BFK.
the price is estimated to be less than $20 for a set :cool:
so yeah, if you can give your opinion and show your interest that can help make my first GB a success. thanks in advance to the geekhack community.
UPDATED in Signature Plastics subforum>> http://geekhack.org/index.php?topic=61123.0
« Last Edit: Mon, 28 July 2014, 07:41:55 by ntw »
Re: [IC] RGB Modifiers in DSA Profile
« Reply #1 on: Mon, 14 July 2014, 20:08:22 »
As a suggestion, perhaps a CMYW set too - to provide a nice contrast for all those Dolch DSA sets out there.
Pic hidden behind MORE in this thread.
« Reply #2 on: Mon, 14 July 2014, 20:13:28 »
I'm interested.  Agreed that a CMY would be good, and I'd probably lean more toward CMYK to begin with.
« Reply #3 on: Mon, 14 July 2014, 22:05:42 »
Given that many (most?) of those who bought Granite would have got RGB sets too (I did!), perhaps CMYW first would make sense.
Or what I was suggesting is to do both as kits available in the one GB.
« Reply #4 on: Mon, 14 July 2014, 22:17:04 »
Yes, both would be good for this GB.  I meant CMYK vs CMYW which you suggested.   :thumb:   I just think it works really solid as a starting point, rather than CMYW which may have contrast issues.
And even though most with Granite will have RGB, those who got DSA Dolch but not Granite will be without it, so it might be good for them.  I am one of these people.  After the separate RGB add-on buy fell through I would still like to get some DSA RGB if possible.  :)
« Reply #5 on: Mon, 14 July 2014, 22:23:16 »
I only suggested CMYW based on the mockup in Dubs's thread I linked above, i.e. this picture:
70866-0
Contrast issues there might be, but the white legends go so well with Dolch :D
« Reply #6 on: Mon, 14 July 2014, 22:26:00 »
Indeed.  The unmodified version also goes well with Dolch though, FTR.   :thumb:   I haven't removed my CMYK from that very board in that photo since I put them on.  :)
Offline ntw
« Reply #7 on: Tue, 15 July 2014, 05:27:24 »
the white legends doesn't go well with the CMYW at all.
and thanks for the suggestion for the CMYK/CMYW set but im planning it for a second GB instead of putting it together with RGB.
Offline Harrowed
  • My wallet has been hacked
« Reply #8 on: Tue, 15 July 2014, 06:36:56 »
Unfortunately those sizes won't work for Ergodox users who use DSA a lot. Separate Dox set could be nice, for example for all keys a pair of 1x and 1.5x plus one 2x. It could become pricey though... 1x shifts probably could be dropped off (?) then it would be 13 keys total.
Ergodox MX Blues | Rosewill RK-9000
Offline ntw
« Reply #9 on: Mon, 28 July 2014, 07:04:55 »
so the groupbuy officially started on PMK. there will be a set for standard layout and another set for winkeyless layout, the link is here>> http://www.pimpmykeyboard.com/deals/rgb-modifiers-in-dsa-abs/
Offline ntw
« Reply #10 on: Mon, 28 July 2014, 07:41:16 »
updated in Signature Plastics subforum>> http://geekhack.org/index.php?topic=61123.0
