Author Topic: 75% Keyboards  (Read 1478 times)
Offline Coff_man
  • hi.
75% Keyboards
« on: Mon, 14 July 2014, 22:44:05 »
I am trying to find a 75% keyboard with Browns and I wanna know of the 3 options (Choc Mini, KC 84, and KTB race/2) is the best?
 Basically, what do you think is the best available board.  :)
-QFR w/ mx Blues
-Ducky 9008 G2 w/ mx Red (dyesub ptb/thin?)
-Choc mini w/ mx Black
Offline exitfire401
  • The Force is Re/\l
Re: 75% Keyboards
« Reply #1 on: Mon, 14 July 2014, 23:06:34 »
I'd say Race 2 for the programability. However, if you're worried about customizing the keycaps, you probably won't want it.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: 75% Keyboards
« Reply #2 on: Mon, 14 July 2014, 23:17:43 »
Choc mini FTW!  Race has terrible keycap compatibility.
Source: Have both.  Had to heavily mod the Race.
Just my $.02,
 - Ron | samwisekoi
Offline Oobly
Re: 75% Keyboards
« Reply #3 on: Tue, 15 July 2014, 02:34:22 »
Keycool 84 is best for keycap compatibility. It has standard sized spacebar and 1.25 and 1x bottom row caps. The only odd cap is a 1.75x shift and most sets with a Tsangan option will include this key. You may have to make do with incorrect legends on the right hand side modifiers and edit keys, though.
Choc mini has nice default keycaps (thick POM), but is more of a PITA to find caps for due to having a 5.5x spacebar.
The Race 2 has a standard spacebar size, but weird sized Esc and Del which are practically impossible to replace since they're top row keys. If you don't mind having 1x keys on those spots (and gaps left and right of the keys) you can find sets that will fit, but you'll need to find extra 1.25x keys for the arrow and edit cluster. Unless of course you're okay with gaps there, too.
So, I'd get a Keycool 84 II, with genuine MX Browns (the latest version of the Keycool 84 uses Kailh switches) if you can find one.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
