Author Topic: Customizer LED swap #540  (Read 2433 times)
Offline Hak Foo
  • Make America Clicky Again!
« on: Sun, 24 May 2009, 23:08:00 »
Well, I decided I just don't like green LEDs.  So I took apart my Customizer 104.
The controller card is mounted somewhat like a SIMM on some old motherboards-- you stuff it in vertically, then angle it down to its final location.
Unlike a SIMM, however, it's secured with only one clip.  (SIMMs had one on the left and right side)  I find this leads to unreliable contact-- This is especially bad with the film-based connector underneath, which can tear and shift, causing keys to go dead in no clear pattern.  I had to disassemble and re-assemble the keyboard several times due to poor or broken contact with the connector.  I fear this will result in dramatically reduced keyboard life.  (my set-aside 1391401 looks up like a neglected dog)
I've tried to limit this problem by adding a stabilization block of hot glue, shown in blue. This should hold the connector in place in spite of the holes being distorted (green lines)
Experience from a previous mod says "keep the LEDs to normal brightness" -- super-brights are distracting.  I used 5mm LEDs, although the originals were 3mm-- the layout has openings large enough for 5mms, and I had them handy.
However, even with the stock LEDs, the black sticker that defines the LED slots and the Unicomp logo is of surprisingly high transparency-- causing you to see an ugly halo around the main rectangle.
I painted over the LED cutouts entirely, from the inside, using cheap art-project paint, then scraped off a tiny spot next to each indicator.  The overall effect was inspired by the tiny, understated red power-on LED on a PS2.
« Last Edit: Mon, 25 May 2009, 01:07:14 by Hak Foo »
Overton130, Box Pale Blues.
Offline Hak Foo
« Reply #1 on: Mon, 25 May 2009, 12:14:01 »
I didn't scrape off the label glue-- I just filled the "shine-through" holes with paint from behind.
