Author Topic: £100ish to spend, Cherry MX Brown TKL/75% Keyboards  (Read 3465 times)
Offline Krydel
« on: Tue, 15 July 2014, 05:08:46 »
Hi guys,
I'm new here; been lurking for the best part of a week and ever since it has become impossible to decide what i want with the wealth of information on here! That said, I thought i'd start up a thread and get some tailored advice if possible. Apologies if I've missed a similar thread, didn't find anything as specific as this.
I'm looking for a TKL or 75% design cherry mx brown UK/ISO layout. This would be my first mechanical keyboard. What exists with the following features that is suitable?
*F Keys - games utilise them.
*Backlit - Preferably red to match other peripherals + the PC, don't care about fancy lighting modes really, constant w/ brightness settings is enough. Could settle for white.
*Regular sized backspace and delete key in usual place. I also use arrow keys all the time.
*Nice keycaps - I've been looking at QFR-i ('rubberised' feel?) though white-only backlight. Not fussed about changing keycaps other than WASD, or maybe if its a programmable keyboard then the F key row to make media keys?
*Media Keys - Ducky Shine 3 TKL has red backlight and is meant to be good, but doesn't have as many media keys as the QFR-i. Play, skip track and volume controls would be great. The original QFR had great media key placement up on the F keys, but they're not backlit and impossible to find in brown ISO over here.
As noted, I've focused my attention on the CM Storm Quickfire Rapid-i which has everything apart from a red backlight, or the Ducky Shine 3 TKL which has a red backlight, but less media keys. In an ideal world, I would still be able to buy a Ducky Shine II w/ browns and red LEDs and be done with it, as thats pretty much perfect for me!
« Last Edit: Tue, 15 July 2014, 05:48:44 by Krydel »
Offline Freebird
    • SSRCG
Re: £100ish to spend, Cherry MX Brown TKL/75% Keyboards
« Reply #1 on: Tue, 15 July 2014, 05:20:40 »
If your heart is set on a TKL with a backlight you have got both what my choices would be in your sights. I would probably go with a Ducky shine 3, the rapid-i does look good too though.
To get nice keycaps you would need to have PBT rather than ABS but as far as I am aware there are no 75% boards that have backlit PBT's.
I originally wanted to get myself a Shine 3 but ended up going for a Poker II in PBT (no backlight) and soldered in my own LED's (easy job). In my opinion it is so much more pleasurable typing on PBT caps than ABS. I am unsure of your particular set of needs but I got used to not having dedicated arrow keys and function row pretty quickly, I thought I may have been taking a gamble on getting a 60% layout but in all honesty now I am so glad I did. You can program your own media keys and stuff on it too as far as I am aware, I have not played with the programming myself though.
Back to your original post and choices I would just go with the Ducky, not heard a bad thing about them.
Offline stakiman
  • Be the change you want to see in the world.
    • Psistorm.eu
« Reply #2 on: Tue, 15 July 2014, 05:36:30 »
Keycool II 84 LED
Search around for it. It can be bought from amazon, too.
SC2 top GM / CS:GO GOD / IT Specialist / HD x264 entusiast.
Offline Krydel
« Reply #3 on: Tue, 15 July 2014, 06:01:07 »
Keycool II 84 LED
If that comes with red LEDs in uk layout that is my perfect keyboard! Can't seem to find it for sale with a quick search though, only the Kailh ones.
Thanks, its still up near the top of the list unless I find something else  :thumb:
« Last Edit: Tue, 15 July 2014, 06:03:08 by Krydel »
Offline frosty
  • jukebox hero
« Reply #4 on: Tue, 15 July 2014, 06:03:05 »
is backlit a must?
in my opinion
• hurts your eyes if you playing in the dark, which already is bad for them.
•adds to manufacturing costs
•abs keycaps almost all the time
i'd recommend a filco, from keyboardsco, or a KUL tenkeyless. both are great boards with great build quality, you can't go wrong with them.
Offline Zacapa
« Reply #5 on: Tue, 15 July 2014, 06:07:16 »
Is there even a 75% keyboard with ISO layout being produced?
Offline Krydel
« Reply #6 on: Tue, 15 July 2014, 06:54:56 »
Perhaps not, you'd know better than i! TKL *or* 75% is fine, though.
(Sidenote: the max keyboard blackbird tkl in red are lovely, but no UK layout  :()
