Author Topic: L-Shape Sata Connector/Adapter?  (Read 4277 times)
Offline Dreamre
    • kbdlife
« on: Tue, 15 July 2014, 19:25:58 »
Hi guys,
I just got my hands on some sleeved MDPC-X sata connectors and I was wondering if any L-shaped adapters that exist. Prior to these cables, I was using sata cables that had a L-shape end. My case seems a bit tight for me to use the sleeved sata cables as is. I've attached an image as a reference...but does anything like that for sata exist?
Offline MattInTheHat
Re: L-Shape Sata Connector/Adapter?
« Reply #1 on: Tue, 15 July 2014, 19:28:24 »
try new egg
Offline exitfire401
  • The Force is Re/\l
« Reply #2 on: Tue, 15 July 2014, 19:28:38 »
Hi guys,
This is the only one I could find. Check monoprice. Usually, they'll have whatever you need.
http://www.thegadgets.co.nz/sata-data-7p-f-to-m-90-degree-extension-adapter-608
Offline Dreamre
    • kbdlife
« Reply #3 on: Tue, 15 July 2014, 19:31:32 »
Hi guys,
Awesome, this is exactly what I'm looking for. Thanks! Now that I know this exists...I can start looking :D!
Edit-
Found it off eBay!
http://www.ebay.ca/itm/SATA-L-Female-Jack-To-Serial-ATA-SATA-Right-Angle-Male-Plug-Convertor-Adapter-/390640519303?pt=US_Drive_Cables_dapters&hash=item5af3fd4887&_uhb=1
Thanks again for all your help! Sadly, monoprice doesn't carry this type of adapter.
« Last Edit: Tue, 15 July 2014, 19:49:53 by Dreamre »
