Author Topic: Paint for metal frame?  (Read 3520 times)
Offline msiegel
« on: Mon, 25 May 2009, 12:54:16 »
hi all :) what's an easy and inexpensive paint to protect a metal keyboard frame?
i'm making a 60-key usb version of an aek ii. here's a photo of the frame in progress. it's cut down almost small enough now...
i'm curious about paint because previously scratched/worn areas of the frame are starting to show rust.
Offline dougy
« Reply #1 on: Tue, 26 May 2009, 06:38:12 »
I'm a long time user of Rustoleum products. Their durability is excellent, but the downside comes from extended drying time. I like to give things 2 weeks before use, preferably in full sun.
Offline ironcoder
« Reply #2 on: Tue, 26 May 2009, 09:34:26 »
Hammerite is cool.
What I do with rustoleum is do super good job of surface prep and hit it with many dusting passes, maybe like 5. Each dusting pass dries much faster. Use a heat gun or hair dryer in between. The last pass can be a heavier one for a glossy coat, heat again or bake in a utility oven. Then a coat of clear and you're done.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline ironcoder
« Reply #3 on: Tue, 26 May 2009, 09:40:12 »
There are all kinds of ovens for drying parts and heat treating stuff but my "utility oven" is whenever your wife says "it's time for a new oven." See what happens then is your old, expensive oven that she couldn't live without goes into the garage and becomes the "utility oven" that is for baking parts and doing other stuff that she would kill you if you did it inside the house in "her" oven.
(ref: see utility washer/dryer (greasy work clothes), utility freezer (deer meat)) You get the idea!
« Last Edit: Tue, 26 May 2009, 09:43:06 by ironcoder »
Offline ironcoder
« Reply #4 on: Tue, 26 May 2009, 09:52:50 »
If you buy her enough new stuff you will eventually find yourself with a totally excellent workshop LOL
Offline lowpoly
« Reply #5 on: Tue, 26 May 2009, 09:54:53 »
Car paint.
Offline ironcoder
« Reply #6 on: Tue, 26 May 2009, 10:25:00 »
I think Imron is going to be a little overkill for a keyboard frame and I doubt he has the gun to shoot it with...
Offline ironcoder
« Reply #7 on: Tue, 26 May 2009, 13:58:47 »
And a respirator. And an OSHA license. And a few hundred bucks for a gallon. And a spray booth.
Offline huha
« Reply #8 on: Tue, 26 May 2009, 17:54:54 »
Almost any paint will suffice. You don't even need to paint it; it's not exposed to the elements, so even if a little rust builds up on the surface, the metal plate will not rust and become damaged. You don't need anything fancy, the cheapest stuff you'll find will most likely work fine.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline msiegel
« Reply #9 on: Tue, 26 May 2009, 22:52:51 »
whew, thanks huha!
so this is what happens when i'm busy during the day :D
you're right, i'm not building a space shuttle here...
Offline ironcoder
« Reply #10 on: Wed, 27 May 2009, 08:39:31 »
A lot of nerve you have, getting us all thinking this was for a kb for the space shuttle. I'm outta here!
And I'm taking my rustoleum with me! LOL
