Author Topic: Bringing back the idea of the Universal Keycaps  (Read 2666 times)
Offline FrostyToast
  • Litshoard
« on: Tue, 15 July 2014, 23:05:32 »
A long, long time back, there was a big thread about a series of sort of little platforms that would go on your switch stems.
There would be ones that would fit on to Topre, MX, Alps, and maybe even BS, however all of the tops would be the exact same sort of shape.
This would allow for universal keycaps that could be placed on any switch you wanted.
I don't have the connections to make something like this happen, but maybe the rest of the folks on GeekHack can work together to make this actually be a thing.
Quote from: elton5354
Offline FrostyToast
  • Litshoard
Offline Oobly
Re: Bringing back the idea of the Universal Keycaps
« Reply #3 on: Wed, 16 July 2014, 02:58:59 »
Perhaps something like IBM buckling spring two-piece keycaps? "Just" need to make MX and Topre lower cap sections.
Or maybe a whole new design, but I'm not sure the best way to connect the keycap "top" to the stem. If it's not done well it could make them more wobbly.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline dantan
« Reply #4 on: Sun, 20 July 2014, 11:06:21 »
did you mean to say oobly?  :D
« Reply #5 on: Mon, 21 July 2014, 20:10:42 »
IBM had already gotten it right during Reagan's first term in office.
The mistake was building the profile into the key caps instead of the keyboard.
"Imagine there's no profile .....
"It's easy if you try ....."
« Last Edit: Mon, 21 July 2014, 20:46:53 by fohat.digs »
- D Trump 2026-10-24
Offline FrostyToast
  • Litshoard
« Reply #6 on: Mon, 21 July 2014, 20:17:58 »
IBM had gotten it right during Reagan's first term in office.
"Imagine no profile .....
If we did manage to find a good way to get this sort of thing going, we could angle and raise/lower the stems of the bottom caps to have the proper profile. This would also make the same top cap fit on both DSA and DCS angled bottom caps.
