Author Topic: Best app for keys remapping? (Windows)  (Read 2017 times)
Offline mougrim
« on: Wed, 16 July 2014, 14:20:09 »
Anyone knows one - preferably, freeware and Windows 8 compatible?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Re: Best app for keys remapping? (Windows)
« Reply #1 on: Wed, 16 July 2014, 14:44:27 »
Well AutoHotKey works pretty well.  Or are you looking for something else with different features?
« Reply #2 on: Wed, 16 July 2014, 14:47:30 »
keytweak (not sure on win 8 compatibility) has been recommended by others in the past. (thanks to esoomenona who recommended it a long time ago)
Offline SonOfSonOfSpock
« Reply #3 on: Wed, 16 July 2014, 18:33:00 »
AutoHotKey is pretty great. I'd recommend it in most cases. It's only downside is that it takes a little bit of time to learn. I've also used SharpKeys. I used it for a while when I only had one key I wanted to remap.
Offline mougrim
« Reply #4 on: Wed, 16 July 2014, 23:49:34 »
Thank you. I'll try this progs :)
I want to remap caps lock to act as control on my Model F.
Offline solar
« Reply #5 on: Thu, 17 July 2014, 00:46:09 »
I can vouch for both of these apps!
Offline ShawnMeg
« Reply #6 on: Thu, 17 July 2014, 00:54:47 »
I tried keytweak on both my work Win 7 box and home Vista box.  It works well, but be careful that there's some malware that may be installed with it.  I may not have been careful when installing it and neglected to decline installing other 3rd party programs.
I used it for my Model M to map my right Alt to Windows Key.  Also, I mapped Scroll lock and Print Screen to Volume Up/Down, right CTRL to Mute.
IBM Model F122 X 2 internal Soarer's || IBM Model M122 internal Soarer's || AEK II SKCM Salmon ALPS external adb_usb converter ||  AEK M0115 SKCM Orange ALPS click mod external adb_usb converter || AEK M0115 SKCM Salmon ALPS external adb_usb converter ||
Offline quake4mhg
« Reply #7 on: Thu, 17 July 2014, 02:05:00 »
AutoHotKey works for me many years :D
Offline atlas3686
  • HHKB Elite
« Reply #8 on: Thu, 17 July 2014, 03:12:26 »
ye autohotkey is probably the best.
Offline cribbit
« Reply #9 on: Thu, 17 July 2014, 13:29:38 »
AHK is by far the best. You can range from super simple (<key>::<key> directly remaps a key) to more complex, such as full on logic for complex alt tab configurations. You can also do a whole messload of things your keyboard never could, such as setting windows to be always on top, removing borders, automatic resizing of windows, string replacement (autocorrect), and much more.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
