Author Topic: Stiffest/heaviest switch type?  (Read 15532 times)
Offline Lammie
« on: Fri, 18 July 2014, 01:51:03 »
What is the most heaviest switch type available? Mx Green?
Topre Realforce 55g
Topre Leopold FC660C 45g
Matias Quiet Pro Mini
Cherry ML G84-4100LPAUS
Cherry MX Green QFTK
Model M Unicomp 103
Re: Stiffest/heaviest switch type?
« Reply #1 on: Fri, 18 July 2014, 01:55:56 »
MX super black?
Offline jacobolus
« Reply #2 on: Fri, 18 July 2014, 02:05:06 »
I think HaaTa has a switch that takes like 400 grams-force or something to actuate.
Offline Oobly
« Reply #3 on: Fri, 18 July 2014, 02:08:45 »
For stock switches, MX Tactile Greys are really heavy (Clear style stems with heavier springs) as are Linear Greys (Black/Red style stem with heavier spring than Blacks).
You could buy some really heavy Korean springs (from here for instance: http://geekhack.org/index.php?topic=55888.0) and put them in your favourite type of MX switch if you want... The 100g springs are apparently like the springs in the Grey switches. He also has some 120g if you want REALLY heavy switches.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Xenderwind
« Reply #4 on: Fri, 18 July 2014, 02:11:43 »
Those springs didnt hit MOQ so I don't believe they will be getting ordered.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #5 on: Fri, 18 July 2014, 03:58:50 »
I believe it would be super blacks unless those were never actually produced. Other than that greys will be the heaviest.
For what its worth someone here found a spring that fit in an MX housing that would not actuate with his Mac book pro sitting on it.
Offline BlueBär
« Reply #6 on: Fri, 18 July 2014, 06:21:21 »
How do you mean that? They're available in a few keyboards, I've had the joy of trying one, they're great ;D
Offline Melvang
« Reply #7 on: Fri, 18 July 2014, 06:41:20 »
I didn't realize that they were mass produced.  I thought that they were just a custom job like ergo clears or ghost blacks.
« Reply #8 on: Fri, 18 July 2014, 06:47:07 »
There's not much but you can see some info about them here http://deskthority.net/wiki/Cherry_MX_Super_Black
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #9 on: Fri, 18 July 2014, 11:40:48 »
So, the heaviest standalone switch I have.
Honeywell Hall Effect, 8-weighting -> 320g
http://deskthority.net/wiki/Honeywell_Hall_Effect
I have at least 3 keyboards with these switches (all different).
Sorta cheating, but my Teletype has double click switches, where the 2nd click exceeds 600g on my digital force gauge (I risk destroying my gauge going any higher).
https://www.flickr.com/photos/triplehaata/sets/72157635829504416/
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
« Reply #10 on: Fri, 18 July 2014, 15:00:02 »
I have a keytronic that has a switch that's roughly as heavy as the heaviest hall effect switches. Since there is an external spring, it would have been very easy for keytronic to manufacture them in different weights.
« Reply #11 on: Sat, 19 July 2014, 03:19:02 »
I prefer stiffer switches, such as MX blacks and greens.
What is the attraction of super-heavy switches, such as MX super blacks and those silly 320g Honeywells?
Offline jacobolus
« Reply #12 on: Sat, 19 July 2014, 04:14:36 »
I have some super-heavy Alps switches that were used for keys like “break” or “stop”; having an extra heavy switch prevents accidental actuation.
« Reply #13 on: Sat, 19 July 2014, 06:05:51 »
For a single key or two, I can understand.  In fact I have done that myself - put an extra spring under a critical key.
Are there any full keyboards of extra-stiff switches anywhere?
« Reply #14 on: Sat, 19 July 2014, 12:00:35 »
"reset" also traditionally is a super-heavy key. I believe it was used to reset the terminal.
Other than RDs, I think the heaviest swtich keyboards I know of are grey MX that ducky put out once.
