Author Topic: How to use an I/O expander  (Read 4315 times)
Offline HotKillerZzz
  • Ammesia
« on: Fri, 18 July 2014, 08:40:51 »
How do you use an  MCP23018 "I/O expander" to link between two custom made hardwired diy ergo keyboard?
Offline swill
  • builder & enabler
    • swillkb.com
Re: How to use an I/O expander
« Reply #1 on: Fri, 18 July 2014, 08:42:14 »
Subscribing. I will need to do this for my hand wired dox and I have not researched it yet.
Offline trishume
    • My Website
« Reply #2 on: Fri, 18 July 2014, 08:51:10 »
  • Ammesia
« Reply #3 on: Fri, 18 July 2014, 10:01:34 »
Then how do you program the teensy to work tgt with it?
Offline bcg
« Reply #4 on: Fri, 18 July 2014, 23:05:19 »
Teensy is a ATmega 32u4 AVR, and can be programmed in C or using the Arduino IDE and libraries.  In either case you will need to write firmware to implement the IO logic, and then you can communicate with the IO expander using an I2C library.  Once your program compiles you load it onto the Teensy using their custom loader program (comes with the "Teensyduino" add on to the Arduino IDE) or via their command line loader (available from the PJRC website I believe).
:wq!
