Author Topic: G80-3000lpceu-0  (Read 5228 times)
Offline Idiot_Hacker
G80-3000lpceu-0
« on: Wed, 27 May 2009, 13:07:51 »
G80-3000 Standard PC Keyboard (USB /PS-2 Combo Key, US 104 Key MX Gold and XPoint) - Color: Light Grey
http://www.posglobal.com/G80-3000LPCEU-0.html
Can someone tell what cherry switch this keyboard has and what is XPoint?
Too many Model Ms to count
Cherry G80-3000LSCRC-2
Compaq MX11800
Dell AT101W
IBM Ultranav
Logitech G15 Version 1
Logitech DiNovo Edge
Offline pmyshkin
G80-3000lpceu-0
« Reply #1 on: Wed, 27 May 2009, 13:19:20 »
Quote from: Idiot_Hacker;92951
I believe the P stands for linear, so blacks.
http://www.cherry.de/english/products/keyboards_G80-3000.htm
Look under "Models"
Offline lowpoly
G80-3000lpceu-0
« Reply #2 on: Wed, 27 May 2009, 13:48:44 »
XPoint: Someone abbreviated Crosspoint (or Gold Crosspoint). It's how the contact inside the switch is designed.
Offline Z Redux
G80-3000lpceu-0
« Reply #3 on: Wed, 27 May 2009, 13:58:58 »
Here are a few pictures showing the crosspoint contact inside Cherry MX switches (about half way down the page).
The link comes from Chloe's Cherry Switches Wiki page.
G80-3000lpceu-0
« Reply #4 on: Wed, 27 May 2009, 16:39:48 »
Quote from: Z Redux;92967
Thanks, I didn't even know there was a wiki for it
Compaq MX11800
Dell AT101W
IBM Ultranav
Offline patrickgeekhack
G80-3000lpceu-0
« Reply #5 on: Thu, 28 May 2009, 08:04:28 »
If you are interested in getting this keyboard, I suggest you try getting someone on the phone from POSGlobal: not an easy task. The system might let you create the order even though they don't any in stock.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline itlnstln
G80-3000lpceu-0
« Reply #6 on: Thu, 28 May 2009, 09:36:02 »
Quote from: ripster;93117
Does anybody know what causes the click SOUND on a blue cherry switch?
It looks like it's caused by the white plastic part hitting the blue part. That would explain the plasticy sound. Webwit described it as "artificial", which is my thought when I switch in a Blue Cherry board for a Model M BS.
Chloe's link is in Japanese and but it seems to indicate vibration and something in that little exclamation bubble as the switch contacts are made.
You're exactly right.  On that same site, there is an animation of how it works.  Basically, the white plastic piece is butted up against the top of the switch and as it passes over the mechanism, the white plastic piece falls and clicks against the stem.
Offline itlnstln
G80-3000lpceu-0
« Reply #7 on: Thu, 28 May 2009, 09:37:22 »
All the way on the bottom of this page is the blue Cherry animation: http://park16.wakwak.com/~ex4/kb/tech_cherry_mx.htm
Offline xyzzy
G80-3000lpceu-0
« Reply #8 on: Thu, 28 May 2009, 09:46:54 »
Here's a direct link to the animation in all its glory: http://park16.wakwak.com/~ex4/kb/tech/cherry_mx_click.swf
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline itlnstln
G80-3000lpceu-0
« Reply #9 on: Thu, 28 May 2009, 10:00:17 »
Quote from: ripster;93124
Did anyone else find that animation strangely erotic?
Well, the switch is made by a company called "Cherry."
Offline itlnstln
G80-3000lpceu-0
« Reply #10 on: Thu, 28 May 2009, 10:15:05 »
Quote from: ripster;93129
LOL - well I knew YOU would!
I didn't say that.  I was just offering a possible explanation. ;)
Offline IBI
G80-3000lpceu-0
« Reply #11 on: Thu, 28 May 2009, 11:55:16 »
OK - now I got it.  The white part springs DOWN.  I thought it would go up.  It's actually hitting the tabs on the blue stem causing the sound (and some spring vibration).
I don't, what's causing the white part to go down in the last step?
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline itlnstln
G80-3000lpceu-0
« Reply #12 on: Thu, 28 May 2009, 13:05:19 »
Quote from: IBI;93133
It appears to be the lack of upward resistance from the leaf.  Once it gets past the leaf, the white piece falls.
Offline itlnstln
G80-3000lpceu-0
« Reply #13 on: Thu, 28 May 2009, 13:41:35 »
There might be a spring in the white piece pushing down.
