Author Topic: Making a switch out of a Cherry switch  (Read 5815 times)
Offline berserkfan
« on: Sun, 20 July 2014, 21:39:39 »
While taking apart my old computer I noticed it was really dirty and started cleaning everything.
Then I started wanting to get rid of the old Power button.
And I started dreaming of turning the power button into a Cherry MX switch using a gray spring.
OK, how should I go about build a normal electrical switch out of a Cherry MX switch?
While we're at it, I don't mind building more similar switches and using them to replace other switches in my house. I'm thinking that if I use two/four gray springs, two/four brown stems and a Tipro 2x key or 4x key, that would make for a very attractive button for my lights or electricity switch.
Please assume that I don't want this to be an expensive project. I can invest in a breadboard, or I can buy diodes, stuff that costs a couple bucks per switch is fine. But please don't suggest that I use a teensy just to convert my computer's power button to a Cherry MX switch!
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Making a switch out of a Cherry switch
« Reply #1 on: Sun, 20 July 2014, 22:17:14 »
At least for the power and reset switches you can just wire the leads from the motherboard headers right to the switch.  Stock power and reset switches are momentary normally open style, the same as cherry and alps switches.  They are just completing a small circuit.  I am going to be doing the same with my custom board project.
As far as using them for other stuff around the house you will want to look at Cherry's spec sheet, because they are not rated for switching very much power.
Offline Zekromtor
    • My Setup
« Reply #2 on: Sun, 20 July 2014, 22:25:19 »
Once upon a time, a company made a mediocre switch and named it after a popular fruit...
And the masses now worship it as idol.
Offline acolombo
« Reply #3 on: Sun, 20 July 2014, 22:27:39 »
That's a very nice idea (the computer part, I don't know if I'd like to have them all around the house) and also a simple mod, I think I'm going to mod my old computer case and make an hole on the top, I only need a spare switch.
The electronical part is really easy, you just have to solder the old power button wires to the new one.
« Reply #4 on: Sun, 20 July 2014, 22:41:44 »
What kind of fruit is a Thorpe?
« Reply #5 on: Sun, 20 July 2014, 23:30:08 »
The company itself is called "cherry", the switch's name is " MX-**** "
and I do agree, after they quit using other people's switches in the late 1970's, Cherry's switches they invented themselves (m6/m7/m8/m11/etc) are terrible.
@OP: When replacing switches here is wha tyou need to know:
The "type of switch" that it is. Now computers use momentary switches, so you can turn them on with just about anything. Something like a toggle switch is (usually) latching. You could use it but it'd sorta-hard to use. Like using an MX lock switch: not ideal at all. Fortunately cherry switches are also momentary, so if you find a place to mount it (like if you have a switch keychain or something) then it's just a drop-in. Wire it up and you're good to go.
The other thing you have to watch out for is the number of poles and throws a switch has. A comptuer power switch is a SPST (single pole single throw) so it's just about perfect. If you wanted to use a toggle switch, a DPST on-off-mom would also work (single pole toggle switches are less common, but a SPST off-mom would work too) THis is just an example.
So cherry switch, arcade button, etc. The sky's the limit! I once wired up a vintage swingline model 13 stapler from the 1930's and used that.
Offline berserkfan
« Reply #6 on: Mon, 21 July 2014, 01:56:21 »
I don't understand 90% of what you said above, but that's ok. I have too many projects now. But will keep this in mind, and when I have time I will definitely start researching all the keywords you gave above.
For an ignorant person like me the most important thing is to have the keywords. Once I know what to search for under wikipedia or Tom's Hardware (feel free to suggest other sources of hardware info), when I have time I can research everything at leisure. For instance I wasn't aware of the concept 'single pole single throw'. But now that I know thanks to you, I am able to attack this problem more effectively!
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #7 on: Mon, 21 July 2014, 03:59:21 »
71804-0
A Ghost From The Past
« Reply #8 on: Wed, 23 July 2014, 19:06:05 »
@OP: When replacing switches here is what you need to know:
read this:
https://en.wikipedia.org/wiki/Switch#Contact_terminology
Just that one section is most of what you need.
A PC needs a momentary connection to turn on. You can use a screwdriver to do this, but a switch is more common.
A momentary switch is only "on" for as long as you hold it. A toggle switch or rocker switch would not work.
Cherry switches are momentary just like a normal PC power switch, so they'll work just as you'd expect. A latching cherry switch would not work however.
That seems to be a better overview. :)
Offline Zekromtor
    • My Setup
« Reply #9 on: Wed, 23 July 2014, 19:10:05 »
They'd work... you'd just have to press them twice. Now that would be something.
« Reply #10 on: Wed, 23 July 2014, 21:26:44 »
The question is: can you actuate them rapidly enough to not cause unwanted behaviour? I know that on at least one of my computers I'd have issues.
Offline Melvang
« Reply #11 on: Thu, 24 July 2014, 14:25:19 »
On any modern hardware it wouldn't make a difference unless you keep it "on" for more than 10 seconds at a shot.
