Author Topic: Korean keycaps?  (Read 21103 times)
Offline Elizabeth
Korean keycaps?
« on: Mon, 21 July 2014, 01:35:35 »
So, looking at a layout for a keyboard and remembering it isn't the easiest thing for me to do. I would like to know where to get keycaps that only show Korean characters. This means no English, just Korean. I'm learning Korean and it's easier for me to look at the keyboard and remember the layout.
I am in IL, USA.
I have a Quickfire Rapid keyboard with CHERRY MX reds.
Sorry if this has already been posted.
Offline ihatefirewalls
Re: Korean keycaps?
« Reply #1 on: Mon, 21 July 2014, 02:08:28 »
I've never seen hangul only keycaps before, either online or in person.
I knew many students from korea and their laptops from Korea always had both English and Hangul on the same keycaps. (I didn't see any when I visited Korea either).
It might be possible to get them custom printed but I doubt it is worth the cost.
If English+Hangul is fine I know imsto.cn has Thick PBTs in Blue and WASD has custom ABS keys.
Sorry I couldn't help more.
Edit: Maybe you could get blanks and attach hangul keycap stickers to the keys. Not the most elegant solution, but works until you learn to touch type.
« Last Edit: Mon, 21 July 2014, 02:10:30 by ihatefirewalls »
Offline Elizabeth
Re: Korean keycaps?
« Reply #2 on: Mon, 21 July 2014, 02:13:36 »
I am fine with getting English and Hangul on the same keyboard.
I don't have the most money, so if it isn't worth the cost, I'd rather just get Hangul+English.
Re: Korean keycaps?
« Reply #3 on: Mon, 21 July 2014, 02:19:29 »
The WASD keycaps are cheaper ($50ish)!
http://www.wasdkeyboards.com/index.php/products/keycap-set.html
You can select hangul under Select Layout.
IMSTOs keycaps are thicker and the material is less prone to shining, but significantly more expensive ($100ish)
http://imsto.cn/index.php?route=product/product&path=62&product_id=62
There might be others but thats all I can recall atm.
EDIT: You can probably just order a set of the alphanumerics since the modifier keys should be the same. Saves u like 20 bucks, but you cant customize the color much.
http://www.wasdkeyboards.com/index.php/products/keycap-mod-packs.html
$30 + a couple dollars shipping & tax
« Last Edit: Mon, 21 July 2014, 02:26:37 by ihatefirewalls »
Offline Elizabeth
Re: Korean keycaps?
« Reply #4 on: Mon, 21 July 2014, 02:29:41 »
D:
gonna have to save up for like a year to afford these.
Offline fuzzybaffy
Re: Korean keycaps?
« Reply #5 on: Mon, 21 July 2014, 03:27:05 »
If you are an ultra-tight budget, you can order some Korean-letter stickers for your keyboard, such as these: http://www.amazon.com/Keyboard-Stickers-Transparent-Background-Lettering/dp/B002DQJ7N0/ref=sr_1_3?ie=UTF8&qid=1405931029&sr=8-3&keywords=korean+stickers
They're, of course, stickers... so they can fall off really easily, which is their down point. But they are cheap.
Or you can order something called "Speed skins", which is a kind of cover that you can put over your keyboard, that will have Korean letters on the cover, which you can then use to type: http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=speedskins%20korean
Never owned them so I can't speak for them. But they seem pretty useful.
Offline Xenderwind
Re: Korean keycaps?
« Reply #6 on: Mon, 21 July 2014, 03:34:06 »
D:
Yeah keycaps aren't usually cheap (good ones at least).  I think with english+hangul keycaps they're mostly (if not all) pbt.  You might be able to find them on classifieds for a little cheaper.  I'd go for a nice two-tone set personally :p.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline cmadrid
Re: Korean keycaps?
« Reply #7 on: Mon, 21 July 2014, 08:01:46 »
If you are on a very very tight budget and just really want one for practicing/learning you could get those korean stickers and super glue them to a crappy rubber dome keyboard
Offline divito
Re: Korean keycaps?
« Reply #8 on: Mon, 21 July 2014, 15:46:34 »
Doing the alpha-only keyset from WASD is the cheapest way to get Korean.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline cribbit
Re: Korean keycaps?
« Reply #9 on: Mon, 21 July 2014, 16:20:06 »
I have a spare set of keys off my MStone Groove87 which had korean + english keys by default. PM'd.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline Smasher816
  • HHKB Master
Re: Korean keycaps?
« Reply #10 on: Mon, 21 July 2014, 16:46:30 »
Ohh my. That brought back memories from grade school. IMHO, those covers are absolutely horrible to type on.
Offline Blaskkaffe
Re: Korean keycaps?
« Reply #11 on: Tue, 22 July 2014, 01:30:20 »
I asked the same question before, got pretty much the same answers.
So then I made a key layout for WASD keyboards for exactly this, everything in korean, no english and even the modifier keys has korean text
My layout file is for ISO keyboard but it would be easy to make it fit ANSI
its possible to change font and colors on the letters, PM me if you are interested in the layout file
Offline clacktalk
  • circa 2015
Re: Korean keycaps?
« Reply #12 on: Wed, 23 July 2014, 18:11:58 »
D:
I just found my endgame MX caps
diary of a clacktalk
radio_killah: too much frank
Offline Hamblet
Re: Korean keycaps?
« Reply #13 on: Thu, 24 July 2014, 17:25:10 »
72342-0
http://www.monsterlabs.co.kr/shop/product_detail.html?pd_no=11457
Hansung, ABS Double shot, White base, Red imprint
KRW 30,000
http://www.monsterlabs.co.kr/shop/product_detail.html?pd_no=11500
Hansung, ABS Double shot, Dark base, Brighter imprint, Dolch imitation
KRW 30,000
http://www.monsterlabs.co.kr/shop/product_detail.html?pd_no=11502
Hansung, ABS Double shot, White base, Blue imprint, Wise imitation
KRW 30,000
72340-1
http://www.leopold.co.kr/?doc=cart/item.php&it_id=1402620672
Leopold, PBT Laser, Dark base, Brighter imprint, Cherry imitation
KRW 35,000
Try to contact with them. You could have one of them, if you are lucky.
And, I do not know clearly whether ALL keys are compatible with yours or not.
Because, nowdays we have thousands of layouts and idiot-mutations.
(But, only for the Hangul/English area, I'm pretty sure, everythings will be fine).
Finally, there should be some more shops out there, I am not that much interested in there.
Regards
« Last Edit: Thu, 24 July 2014, 17:40:20 by Hamblet »
Offline Heezy
  • Formerly trynds
Re: Korean keycaps?
« Reply #14 on: Thu, 24 July 2014, 17:30:01 »
Holy crap, it's Hamblet!
Rig - i3 6300, 240GB SSD, 500GB SSD, Gigabyte H170N Wifi, 16GB DDR4, Zotac 1060 Mini, 650w SuperFlower
Monitor - HKC144hz Mouse/Mousepad/Keyboard - Zowie EC1A - Zowie GS-R - Zowie Camade - Filco TKL MX Pink
Offline Hamblet
Re: Korean keycaps?
« Reply #15 on: Thu, 24 July 2014, 17:34:17 »
Yeah, it's me. So...?
(Nice to see You.)
Offline Hamblet
Re: Korean keycaps?
« Reply #16 on: Thu, 24 July 2014, 17:50:45 »
Got one more
http://www.pcgear.co.kr/shop/item.php?it_id=1384479575
PBT Laser, Lots lots of colors, Regular ones and a little bit brighter ones. 37 Keys only.
KRW 19,000
72349-0
Offline Hamblet
Re: Korean keycaps?
« Reply #17 on: Thu, 24 July 2014, 18:19:04 »
And I have talked with one of the sales dpt. guy of the Hansung.
They can give you the PBT Laser (White base, Black imprint) for KRW 45,000.
(It's not a regular salse items, it's their spare parts for the repairs).
