Author Topic: What is the switch used on this keyboard?  (Read 2183 times)
Offline nrp
« on: Thu, 28 May 2009, 21:38:14 »
Would appreciate any info. Seems to be a nice piece of equipment.
http://www.goldtouch.com/p-65-goldtouch-ergonomic-adjustable-keyboard-white.aspx
Offline zwmalone
« Reply #1 on: Thu, 28 May 2009, 21:43:13 »
Rubber domes.  Lam had one of these.
Can't get enough of them ALPS
Offline vils
« Reply #2 on: Thu, 28 May 2009, 21:46:00 »
Rubber dome springs, says their faq
« Last Edit: Thu, 28 May 2009, 21:48:19 by vils »
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline nrp
« Reply #3 on: Thu, 28 May 2009, 21:52:16 »
Thank you
Offline skriefal
« Reply #4 on: Thu, 28 May 2009, 22:23:01 »
I picked up one of these for $3 a few weeks ago.  Should actually try it some day soon... :)
