Author Topic: British lube  (Read 2214 times)
Offline FerretBuster
British lube
« on: Wed, 23 July 2014, 17:05:32 »
Hey guys, haven't posted on GH in a loooooooong time.
Like 2 years maybe.
Anyway, I was wondering if any of you know where I can get some lube for costar stabilizers in the UK. I checked out ripster's lube guide, and I checked out his recommendation - which I can probably purchase from some bike websites, but i'd prefer to use amazon or similar.
Can anyone recommend me anything?
Cheers.
Offline Hzza
Re: British lube
« Reply #1 on: Wed, 23 July 2014, 17:08:45 »
I've been using this stuff, works fine on the stabs, not sure what it would do to the insides of a switch though.
http://www.amazon.co.uk/gp/product/B000L97ZPI/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
Re: British lube
« Reply #2 on: Wed, 23 July 2014, 17:12:49 »
Was literally just looking at that stuff, packet scared me off a little. How long have you been using it on your board, no signs of it messing with your kb's plastic?
Thanks.
Offline Hzza
Re: British lube
« Reply #3 on: Wed, 23 July 2014, 17:15:29 »
Amazon said I bought it in August, so it's probably been on my boards for a year or so. I've seen no signs of any trouble on the plastics and the stabs are still smooth as the day I put the stuff on.
Re: British lube
« Reply #4 on: Wed, 23 July 2014, 17:18:19 »
Brilliant, i'll order some now. Cheers for the quick response :)
