Author Topic: Extensive Cherry MX article -- in Korean :S  (Read 2452 times)
Offline msiegel
« on: Sat, 30 May 2009, 16:22:41 »
this looks like a great article on the ins and outs of cherry mx switches... unfortunately i can't read the korean :'(
http://www.kbdmania.net/xe/best_article/638315
good pics though :)
Offline watduzhkstand4
« Reply #1 on: Sat, 30 May 2009, 16:40:39 »
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&u=http%3A%2a%2Fwww.kbdmania.net%2Fxe%2Fbest_article%2F638315&sl=ko&tl=en&history_state0=
the link is the google translated version. Even after translating the page, some words still seems weird.
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline IBI
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline msiegel
« Reply #3 on: Sat, 30 May 2009, 17:56:01 »
thanks... it's not as extensive as i thought. there are a few gems in the robotic translation:
"Arrow points to the contact sheet, and is literally jammed damn ants legs are slipping."
Offline huha
« Reply #4 on: Sat, 30 May 2009, 19:50:57 »
I hope I can give some more information on Cherry switches soon. I did ask Cherry for datasheets and whatnot, so I'll see what I can get. In parallel, I did some measurements, but measuring and getting results take massive amounts of time if you're quite occupied with all kinds of other things as well ... initial measurements have been done over a month ago and I'm still trying to find the time to actually enter loads of data of some different measurements carried out about two months ago.
I don't think it should be very revealing. Cherry switches are quite simple, actually, but there are some subtleties I'd like to investigate. Yet, no time for great endeavors, so a couple of hours per week have to suffice, slowing everything down by incredible amounts. Next week, my G80-11800 should arrive, which should give me brown and the other grey switches to dissemble and fuss around with. Oh my, this is almost poised to be great fun indeed.
edit: So far, I can confirm springs used in MX greens are identical to those in MX blacks, unless of course Cherry is playing some bizarre joke on me.
-huha
« Last Edit: Sat, 30 May 2009, 19:53:08 by huha »
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline msiegel
« Reply #5 on: Sat, 30 May 2009, 22:35:22 »
i've been cleaning a set of white Alps with dampers for an AEK II conversion, hence my interest in switch guts :)
i miss Chloe. probably abducted by rogue mechanical engineers to do secret missions on monster island... :-/
