Author Topic: What is the spacebar size for poker II?  (Read 6325 times)
Offline keypro
  • * Commercial Vendor
« on: Sat, 26 July 2014, 05:54:22 »
I'm interested in buying new spacebars since its original spacebar looks horrible with stupid quote. Any recommendation for the brand of spacebar for poker II kb? Pictures would be great too.  Any input would be highly appreciated.  Thanks!  :))
Offline withanx
Re: What is the spacebar size for poker II?
« Reply #1 on: Sat, 26 July 2014, 09:21:24 »
The space bars from WASD fit the Poker II.  I have a set of orange caps I put over the function keys because of the terrible space bar.
Offline messcher
« Reply #2 on: Sat, 26 July 2014, 11:09:04 »
I was kind of interested in the same thing. Just did a little googling... in private... and found it was 6.25.
Poker II via deskthority
http://deskthority.net/wiki/Keycap_size_by_keyboard
Poker II via WASD
http://support.wasdkeyboards.com/customer/portal/articles/1366948-keycap-compatibility
Offline keypro
« Reply #3 on: Sat, 26 July 2014, 11:17:46 »
Thanks! I will be looking forward to WASD.
Offline keypro
« Reply #4 on: Sat, 26 July 2014, 11:20:25 »
Poker II via WASD
Nice! Thank you for your pictures. Much appreciated! now the next question will be which materials of spacebar I should get.  :p
Offline Quardah
    • DeliTech
« Reply #5 on: Mon, 28 July 2014, 10:25:13 »
Poker II via WASD
Anything else than ABS (PBT, POM, PVC, PC). You will use the spacebar mostly at the same place and is mostly on of the top 5 keys you'll use the most. ABS spacebar will shine on spots after less than a year or so, and that'll litteraly look and feel horrible.
Picture for reference while it's a little bad you get the idea : http://photopost.vrforums.com/500/medium/keyboard11.jpg
PBT is hard to find but defenetly worth a shot. Anything else is stepping down for aesthetics because the stock Poker II spacebar is quality PBT. And Functionnality over Aesthetics, always.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline keypro
« Reply #6 on: Mon, 28 July 2014, 10:47:26 »
Poker II via WASD
Thank you for your input. I will get a PBT spacebar and may get aluminum one also for my personal preference.  ;)
